Hello everyone, we originally planned only one ceiling connection in the dining room, but now we want to install two ceiling lights there. The idea is to have the lights hang over the dining table, one over each half. We are looking for a way to achieve an elegant and stylish cable management. A standard plastic cable conduit is only an emergency solution. The ceiling lights have already been chosen. They will be the Ikea Hektar. Best regards, Alex
Sebastian798 Apr 2016 13:37Yes, the plaster will probably only be about a millimeter thick (around 0.04 inches) – try scraping that off.
nordanney8 Apr 2016 13:39Sebastian79 schrieb:
Yes, the plaster might only be about a millimeter thick there – try scraping that off Why? Here we have about 20mm (0.8 inches) of plaster, similar to the walls.
Sebastian798 Apr 2016 13:58How is that supposed to work? Why would anyone do something like that?
I’m just going to flat out doubt it.
nordanney8 Apr 2016 14:15Sebastian79 schrieb:
How is that supposed to work? Why would anyone do that?
I’ll just boldly doubt it It’s plastered just like the walls. That’s a common practice. Even my apartments from the 1950s have plaster of this thickness on the ceiling. Maybe it’s only 15mm (0.6 inches).
You can doubt it, but that’s really how it is.
Hold the hose to the ceiling, start plastering, smooth it out.
Sebastian798 Apr 2016 14:18This is not normal with precast concrete elements – first of all: why? Why would you apply a thick layer of plaster?
And then the how – simply holding a hose against it doesn’t work, because it wouldn’t adhere to the concrete at all. Have you seen this yourself? Have you tried it?
It’s already a hassle even on concrete walls.
It’s definitely not common practice; usually, a thin layer of filler is applied, resulting in a very good ceiling finish.
nordanney8 Apr 2016 14:26Well, I’ve seen this myself with our cast ceiling, our interior concrete walls, and our previous house (which had precast concrete slabs). It didn’t look like a struggle. The concrete just needed an appropriate primer (it was quite “sandy”), and there wasn’t much splattering.
Then I noticed the same in five condominiums (built between the 1950s and 1970s) — not how it was done, but the final result.
Also at various neighbors’ places.
I find this quite common here.
That’s why I used the (unprofessional) screwdriver method.
