ᐅ Two Bathrooms: Where Should Tiles Be Installed?
Created on: 2 Jan 2022 11:41
Pinkiponk
I would like to ask for your opinion regarding aesthetics and practical usability:
I want to install as few tiles as possible on the walls. Attached are the floor plans of our bathrooms on the ground floor and upper floor (marked in red). In your opinion, where should tiles definitely be installed, and what alternatives would you suggest?
I wish you and your families a Happy New Year, with many joyful moments here ;-) and beyond the forum. Let’s continue to come together in such a positive and helpful way.
--> And if anyone has contact with Hampshire, please use all available means to encourage him to return. He is greatly missed here.
Floor plan of a residential house: living room, kitchen, and hallway; red area marking bathroom and utility room.
Floor plan of a house with Study 1 and 2, corridor, bathroom, bedroom, sauna; red border.
11ant2 Jan 2022 17:53
Pinkiponk schrieb:
Do you really find them that bad?
No, not as shown in the picture (especially in the shower). In the Fleischerhaus, it comes across more like a nasty prank.
driver55
2 Jan 2022 17:59
When you build, or have built, a "dance pool" and don’t even know how or with what to fill it.
I would definitely have called a "bathroom designer" to make it look really nice.
Instead, the question is where to stick the tiles.
Some things, huh. 🙄
2 Jan 2022 18:19
But please, not that gimmick from the butcher’s shop...
I was just thinking the same...
Basically, if you want decorative tiles, you should plan them together with the design of the fixtures and fittings; otherwise, it looks really poor – as has already been shown here in the forum.
motorradsilke
2 Jan 2022 18:29
Pinkiponk schrieb:
Do you really find them that bad? I know bathrooms these days are usually designed differently, but I like the color spring green; it always cheers me up. ;-) We will use it sparingly as well.
[ATTACH alt="zwei-baeder-wo-sollen-fliesen-hin-548121-1.jpg"]68337[/ATTACH]
You and your husband have to like it.
pagoni2020
2 Jan 2022 19:14
@Pinkiponk I have always been quite bold with colors too... sometimes even a bit too "bold"! In my former house, we were excited—fresh from the trade show—about the latest craze: a very expensive green Hoesch bathtub and washbasins with "ears," similar to how today you often find huge tiles displayed in the entrance area of tile stores... always the trendiest stuff. We paired these with matching bright red tiles and red fixtures, as suggested by the Italian designer on the flyer. We didn’t mind it ourselves; we got used to it and even found it amusing. However, it was way too expensive (because it was trendy), and every time I visited other bathrooms, I realized that my next bathroom would have calm colors, and I would rather add color with interchangeable elements. Back then, we also had the tall tubular radiators painted in different colors at the car body shop... 🤨
What I want to say is: while I completely understand the desire to use bold colors, I would avoid this in permanent areas such as tiles. For plastered walls, though, I can imagine going really bold.
I have a "feeling" that since you have seemed a bit discouraged for a while, maybe there’s pressure to do something drastic in the bathroom where, in my opinion, a more thoughtful approach would be better. After that, you can try out painted walls, quirky bathroom furniture, and so on.
We also had the misconception that a bathroom could be radically redesigned afterward and ended up with a large room with sanitary fixtures on every wall. I would advise against that for you (and your husband) as well. Years later, we turned it into two bathrooms and added an en-suite bathroom to the bedroom, which was wonderful.
You still have the chance to plan and design your bathroom carefully... while you can... so why wouldn’t you both find a compromise?
2 Jan 2022 19:52
I have to admit, earlier I was searching this forum for a former user who, when still active, had also shared pictures of their shower toilet and children’s bathroom. Those tiles were exactly as intended: the grass clearly recognizable as growing (not cut) grass, and with individual tiles also featuring drawn animal heads.
At first, I thought of @Doc.Schnaggls, but later it was probably more @toxicmolotof… neither of whom are active here anymore. While searching for Louis and Ella, a few more posts appeared, unfortunately without photos. @Peanuts74
So here is something from the internet:
Personally, I sometimes like things to be a bit exotic, special, or bold. Children’s tiles or white gradients don’t really fit that. The latter reminds me of 80s tie-dye.
In such cases, I would always recommend sticking to a wall design that can be easily changed—that is, using neutral tiles that support a variable and bold wall design on the sections that are not tiled. That is basically the reason why not all walls are tiled, so that some can be specially decorated.
Bathroom wall with giraffe and zebra patterns, grass-green tiles, and coat hooks.
