ᐅ TV Installation in New Construction
Created on: 17 Jan 2015 22:00
kernm23
I am currently planning my house.
The following features are desired:
Satellite reception, output to one TV and multiple mobile devices (iPad, laptop, etc.), simultaneous viewing of different channels on the TV and on the iPad/laptop, recording on a Synology NAS, streaming from the NAS to various devices, access to media libraries.
(Note: The TV currently does not have a built-in receiver but is intended to be replaced in the medium term by a TV with an integrated receiver and network access.)
Operation should be straightforward with as few devices as possible.
I want a future-proof, cost-effective solution with minimal additional equipment.
What do you think of the following proposal:
As long as there is no TV with a built-in satellite receiver and network access:
- Satellite dish
- Existing Dreambox as satellite receiver for the TV and as network gateway for NAS streaming and media libraries
- Two satellite outlets in the living room (one for the Dreambox, one reserved for later use for direct NAS recordings on the Synology NAS)
- One LAN connection per room
- Wi-Fi covering the entire house
- Live TV from the Dreambox can also be watched on the iPad/laptop (but only the same channel)
Later on:
- Satellite dish
- TV with integrated satellite receiver and network access for NAS streaming and media libraries
- Two satellite outlets in the living room (one for TV reception, one for NAS recordings via Video Station)
I have the following questions:
Would it be better to avoid satellite outlets in the house entirely from the start and convert the satellite signal into an IP signal?
How can I watch different satellite channels on the iPad/laptop?
Are there TVs that receive channels via network connection?
Can I record TV programs on my NAS using the network connection (Video Station)?
Does anyone have experience with Sat-IP receivers?
Thank you.
Boergi
20 Feb 2015 08:18
Hello Kernm,
regarding your questions:
Or would it be better to skip satellite outlets in the house and convert the satellite signal directly into an IP signal?
I wouldn’t recommend that; satellite-over-VoIP technology is not yet really suitable for mass use.
How can I watch different satellite channels on an iPad/notebook?
If you want to watch different channels simultaneously on an iPad and a notebook, you need a streaming device with multiple satellite tuners (such as a VU+ Solo² or similar).
Another option is to watch the stream from your Dreambox on the laptop and stream from the Synology to the iPad.
There are some models available, for example from Panasonic, but the selection is still limited.
Can I record TV programs on my NAS via network connection (Videostation)?
With a Synology DiskStation, you can record, stream, and share videos over the network and the internet via DLNA or the dedicated app (Videostation). You only need a USB satellite tuner for that.
You can also have recordings from the Dreambox saved on the DiskStation and then distribute them from there.
In the rooms, I would suggest installing a double LAN outlet straight away; the TWIN cable and the outlet won’t cost much more. In the hallways, near the ceiling or on the wall, also consider a connection point for Wi-Fi access points.
If you plan to place the DiskStation near the TV, I would recommend having at least three TV connections there (2x satellite receiver, 1x DiskStation).
Regards,
Sebastian
Umbau-Susi20 Feb 2015 15:21
I have to jump in here right away with a bunch of questions, sorry.
I own a Synology DiskStation and a satellite system on the roof with outlets in different rooms. How exactly can I record to the DiskStation? Asking very excitedly about this possibility.
Sylvia
Saruss
20 Feb 2015 21:51
I have a Kathrein receiver connected to a satellite dish/TV, which is quite an all-in-one solution, though not exactly inexpensive. Besides the usual TV and recording options, it also streams over the network, allowing you to watch live TV, recordings, and movies from the NAS on any PC/tablet anywhere (including NAS to TV).
I am satisfied with it, and my wife (who uses it much more) is as well, thanks to its easy operation.
Umbau-Susi21 Feb 2015 07:48
I have done some reading on this topic. What I have in mind, when I make changes (I am responsible for networking and such in our case), is to have a device that allows simultaneous recording and viewing of another program, has its own 500 GB (about 1/2 TB) drive—preferably SSD—and is network-capable (for Synology backup).
I have found most of the requirements, except for the network connection. Or is that so standard nowadays that it doesn’t even need to be mentioned?
Would you mind telling me which one you have?
Sylvia
Sebastian79
21 Feb 2015 08:01
Buy a VU+ Solo2 or Duo2, that way you have everything...
Koempy21 Feb 2015 09:43
Lexmaul79 schrieb:
Buy yourself a VU+ Solo2 or Duo2, that covers everything...
That's a good choice, but it requires some time to get familiar with. However, they can basically do everything. You can record over the network. With appropriate software, they can also decrypt HD+ and Sky cards, but only with a legal subscription and you can record and watch something else at the same time.
