ᐅ Are your truck tires already worn out?
Created on: 18 Nov 2021 00:02
Seven1984
Seven1984
18 Nov 2021 00:02
Hi,
I’m not very familiar with truck tires, so I hope you don’t mind my basic question and that you can help me assess this. For a car tire, I would say it’s worn out and needs to be replaced. Would you say the same for this truck tire, or does it still have enough tread for another 15,000 kilometers (9,320 miles)? Thanks a lot :-)
Thanks, regards
Close-up of a car tire with a noticeable bulge on the sidewall and mud on the ground.
Between two large off-road tires, there are small stones on an unpaved surface.
HilfeHilfe
18 Nov 2021 05:26
well, that already looks really bad
O
Obermuh
18 Nov 2021 06:15
Wear (profile worn down) is not the issue here; they are simply damaged.
guckuck2
18 Nov 2021 06:36
Dents usually result from impact fractures, meaning that something has hit the surface somewhere and damaged the structure beneath.
No idea about the profile. Measure it and look up the relevant regulations and recommendations.
You could probably remove the small "stone" as well, unless it's a load-bearing component ;-)
Hutchinson123
18 Nov 2021 07:10
The dents really unsettle me...
And the profile is already worn down. The markings for the minimum depth are partially worn off.
They're simply finished.
Seven1984
18 Nov 2021 08:02
Thank you for the opinions. The tires don’t belong to me, but the dents were probably caused on my construction site, and the owner would like new tires at my expense. However, since the tires, as you already mentioned, are worn out, I don’t see it that way. I am on the same page regarding the minimum tread depth; I just wasn’t sure if the rules are different for trucks since I don’t really have any knowledge about tires. They should roll properly and have enough tread – I don’t have any other opinions about tires. 🙂 But sorry, I should have explained this better in the first post – it was misleading that way. 🙂
