ᐅ Trouble with the Electrician / Allowable Tolerance Range?!
Created on: 21 Jan 2019 18:52
Laynne
We are in the process of renovating our house and are currently having more or less trouble with the electrician.
We got a quote from one of the largest electrical contractors in the area for a complete rewiring of the electrical system and were quite impressed at first. However, a week after the work started, the situation looks very different...
- An electrician came who has just recently completed his apprenticeship
- He prefers chatting with the other tradesmen instead of actually getting work done
- He laughs at the 3-week schedule and says he needs to see when and what he can accomplish
- Every single socket outlet still needs to be discussed with us again, even though we marked everything with marker paint
- He doesn’t mark the chases, but just cuts straight into the wall (and it looks exactly like that!)
- Cable conduits apparently cannot be installed inside the wall due to the structural stability (11.5cm (4.5 inches) bricks), which was previously agreed differently
After 3 days, we had enough and called in the manager.
He inspected the work and said everything was within tolerance.
Marking the chases beforehand would take more time and was not part of the scope of work. (Is this a joke or???)
After that, things improved slightly and the electrician managed to get a bit more done each day.
Today, I noticed that the light switches in the rooms are not all at the same height and the sockets (those black inner trims) have all been installed crooked.
Sockets were originally agreed to be below the light switches but are now located near the floor.
Also, the preparation for the ceiling lamp is not centered in the room.
And it goes on...
Is this really all still within the tolerance range??
Verfallene Innenwand mit Deckenriss und rostigen Rohren; Tür mit Glasfenstern im Hintergrund.
Beschädigte weiße Säule mit zwei dunklen Rohröffnungen und bröckelndem Putz
Wand mit abblätternder Tapete, braune Flecken; senkrechte Reihe aus fünf schwarzen Abdeckungen.
Unfertiger Raum: Wand mit Kabelverläufen, rote Markierungen und Müllsack auf dem Boden.
fach1werk
1 Aug 2019 08:12
I would have the moisture levels in the wall measured to be absolutely sure when it is dry enough. This is usually done by a leak detector as well. The measuring devices vary greatly depending on their price. The mid-range device that a tradesperson might quickly buy and just keep in their pocket is not good enough! You could ask the building insurance first. Water damage is water damage, and who pursues recourse afterwards should not matter to the homeowner. I would recommend contacting the insurance; they can also recommend a leak detector. The detection – which includes moisture measurement – is often covered by the building insurance in principle, usually carried out by an expert; this does not apply to the repair work.
Good luck to you! Every construction company makes mistakes; the difference seems to be in how they make good on them.
Best regards, Gabriele
