ᐅ Treating interior plaster with lime-cement plaster
Created on: 16 Jan 2008 21:27
U
Unregistriert
U
Unregistriert
16 Jan 2008 21:27
How should interior plaster (lime-cement plaster) be treated before proceeding with the following applications?
- painting
- wallpapering
What exactly is the difference between primer and sizing?
Sandy
21 Mar 2008 13:09
I would recommend priming the surface with a deep-penetrating primer; it is relatively inexpensive and quick to apply. Another advantage is the fast drying time.
Using a lining paper is advisable for wallpaper to ensure the seams hold better. However, if you plan to paint and then wallpaper, it’s better to treat everything with a deep-penetrating primer. This also improves the durability of the wallpaper because the plaster becomes saturated, preventing the adhesive from being absorbed too much by the plaster.
Regards,
Sandy
schwarzmeier
10 Jan 2009 02:17
Fresh or new lime gypsum or gypsum plasters, regardless of what will be applied on them, must be primed with a deep-penetrating primer. If wallpapering is planned, a brush- or roller-applied lining coat should be applied first to ensure adhesion for the wallpaper.
Lily
12 Jan 2009 07:31
I would also recommend treating it with a primer, as new plaster absorbs moisture very strongly, meaning you will need much more paint without it. It is also important that the substrate has dried long enough; I would say at least 6 weeks.
Lily
13 Jan 2009 07:25
I had a wall in my house replastered, and the painter advised me to wait for 6 weeks before applying anything on it. I followed this advice and then wallpapered. I just used a bit more paste and didn’t do anything else, and everything is holding perfectly.
Lily
13 Jan 2009 07:35
I did the same with the wall; I waited 6 weeks and then painted it as usual. I didn’t notice any difference when painting. However, my wall has a gypsum plaster finish, so I’m not sure what type of plaster you have and whether that makes a difference.
