Guido198026 Jan 2020 10:11I have a question about the facade. The plan is to have the facade partially finished with plaster and partially with brickwork.
The horizontal transition should be relatively straightforward, but what about the vertical transition at the corner? Is this a technical issue, or is there a simple technical solution to ensure it looks good visually afterwards?
Guido198026 Jan 2020 13:02Golfi90 schrieb:
Horizontally, this is built to a certain "thickness" and sealed with white acrylic.
Optionally, a drip edge can also be installed.
Vertically, it is probably handled the same way. Vertically, this doesn’t really work well at the corner... then you would basically have to miter cut the brick and the render/ plaster.
[The façades discussed can be found at https://www.hausbau-forum.de/threads/rolllaeden-Farbe-bei-weissem-Haus-mit-klinkeranteilen.33620/]
It seems inconsistent to me, but if it is a person’s will, then so be it: I would start the brick cladding (viewed from its visible surface) “too early” enough so that the joints align flush with the plaster surface of the adjacent façade at the corner. This way, from the gable side, you only see the thickness of the facing bricks.
