ᐅ Repainting Billy Regal color variants – mixing paints?
Created on: 17 Apr 2023 18:37
Chaoni
Chaoni
17 Apr 2023 18:37
Hello everyone, I am planning to change the color of a Billy bookshelf that I own. I want to replicate as closely as possible the different color variations that IKEA offers for this model. My main question is: How well does the paint adhere to the Billy bookshelf when trying to match the original shades exactly?
I am especially interested in whether it is advisable to mix the colors myself to achieve the right tones, and if so, which methods or mixing ratios should be used. I am concerned not only with blending base colors but also with effects like matte or glossy finishes and shades that lean toward gray or beige.
Are there common issues with repainting like this, for example, the paint behaving differently on the wood surface or the need for special primers? I would appreciate any tips or experience reports that can help me complete the project with minimal effort and a good final result.
sinhau
17 Apr 2023 19:06
Hello Chaoni, I have some experience with repainting furniture like the Billy shelf and can recommend a structured approach.
First: Are you sure which color variant of the Billy you want to replicate exactly? For example, IKEA often offers white, ash, or various shades of gray. Comparing the original can or RAL color codes helps a lot.
Regarding mixing paints: It is definitely possible to mix colors yourself, but with some limitations. IKEA paints are often based on standard acrylic coatings, which can be water- or solvent-based. For a clean result, I recommend the following steps:
1. Thoroughly clean the surface and, if needed, lightly sand with 240-grit sandpaper to ensure good adhesion.
2. Apply an appropriate primer, since Billy usually has melamine-coated panels that otherwise hold paint poorly.
3. For mixing, standard acrylic paints from common manufacturers work best, as they can be adjusted well in small quantities. If you aim for precise shades, a visit to a paint specialist shop with a color matching device is worthwhile; they can often match colors exactly based on a sample.
4. Be careful with finishes: matte or glossy effects are achieved by the correct clear coat as a final layer. Matte sealing is often used to maintain the “IKEA look.”
Common issues include an uneven surface or uneven color coverage if the primer is missing or the paint is applied too thickly. Drying too quickly can also cause problems.
In short: mixing your own paint is possible and makes sense if you have a clear goal, but the right equipment and preparation are crucial.
If this sounds too complicated, IKEA often offers replacement parts or touch-up sprays for repairs.
I hope this helps you as a starting point! 🙂
Trate47
17 Apr 2023 20:45
Hey,
great topic! I always find it exciting to customize IKEA furniture a bit. :-)
Regarding your question: repainting the Billy shelf is a great idea, considering how many color options there are. I have tried it myself and found that mixing your own colors is fun but can also be tricky. Especially since the surface of the Billy is so smooth, proper preparation is essential; otherwise, the paint won’t adhere well.
sinhau schrieb:
Apply an appropriate primer, as Billy often has melamine-coated panels that otherwise hold paint poorly.
I can only emphasize that! I only achieved a good result after sanding and priming.
Chaoni schrieb:
… especially for effects like matte or glossy finishes …
For me, matte clear coat worked really well; it gives the surface a higher quality look and makes it less prone to fingerprints and scratches.
Mixing your own colors is a cool challenge, but I would always recommend testing on leftover pieces first. With standard acrylic paints from the hardware store, you can achieve many shades, but professional color matching services save frustration in the long run.
Best regards and good luck!
Domau0
18 Apr 2023 08:11
Hello Chaoni, I would like to elaborate on your question a bit more, as the success of repainting the Billy bookcase depends on several factors, and the color nuances are influenced not only by the shade but also by the surface texture.
First, it should be noted that the panels of the Billy bookcases usually have a melamine resin coating, which is durable but not an ideal base for painting. Therefore, careful preparation is essential. You should:
- Thoroughly clean the surface to remove dust and grease.
- Use sandpaper with a grit of around 240 to lightly scuff the surface, making it matte without removing too much material.
- Apply a primer designed specifically for paintable melamine resin surfaces. Polyurethane or special acrylic primers are common choices here.
sinhau schrieb:
Apply a suitable primer, because Billy often has melamine-coated panels that otherwise do not hold paint well.
Choosing the right color is a second, often underestimated step. Since IKEA uses proprietary color formulas, it is difficult to reproduce the exact shade simply by mixing primary colors. For white or gray variants, the undertone can also shift slightly toward yellowish or bluish depending on the lighting and material thickness.
Regarding color matching itself: For an accurately mixed result, it is advisable to use a professional color matcher who uses a spectrophotometer to determine the shade from a sample and then reproduces it precisely. This also allows simulating a matte or satin finish. The paint should be water-based to minimize odor and ensure better flow.
Additional points to consider:
- Using a spray gun generally achieves the most even result but can be labor-intensive for smaller projects.
- For brush or roller application, special furniture or acrylic paints are recommended that do not drip or leave strong brush strokes.
- A final matte clear coat protects the surface and provides the typical texture.
Which method you choose also depends on your equipment. It is also important to consider the size of the bookcase and whether you can work the entire surface evenly.
I am curious: Which color(s) do you want to repaint exactly, and what materials do you plan to use? Do you already have a color sample? This would help to give more specific advice.
te-min
18 Apr 2023 09:26
A brief note on the topic: Mixing your own paint is possible, but it is only truly precise with a color measuring device.
Priming is essential; otherwise, the paint will not adhere to the melamine surface.
You can control the finish, matte or glossy, using clear coat.
You can also specifically use acrylic paints from specialist suppliers, which dry well and produce little odor.
