ᐅ Looking for a single rocker switch with a double-pole function; Gira does not offer this.
Created on: 15 Jun 2021 15:07
i_b_n_a_n
Today, I wanted to list and order our electrical equipment and was a bit surprised that a rocker switch I wanted is not available for purchase 😳
The specialist dealer was not aware of such a switch, and according to Gira, they definitely do not have this type in their current product range.
I am looking for a rocker switch that has a single-pole normally closed contact both at the top and at the bottom—so two separate normally closed contacts. Double rocker switches or double push-buttons are available but are not what I want.
Like in the picture below (showing a rocker for a switch), I would like a single rocker with two normally closed contacts (top/bottom).
Are there any other manufacturers who currently make such switches, with a similar appearance and price range as the Gira 55 pure white glossy?
Thanks for the feedback. It seems I stuck too closely to my design preference and didn’t want to accept the standard solution 🙄. The only issue with that standard solution is that I simply like the other rocker switch better 😎. It’s a pity, but it seems such an implementation is not in demand. However, it’s not a big deal for us to go with the normal roller shutter switches with double rocker.
i_b_n_a_n schrieb:
okayyyyy, but I would actually prefer it the exact other way around. Unfortunately, that doesn’t work 😡Sorry, then I misunderstood. In that case, you obviously need two springs. It also works the other way around. Just google for “conversion push-button switch Gira” 😉Similar topics
