I am about to move and own several Ikea Brimnes furniture pieces, mainly dressers and bed frames. Since I won’t be able to reassemble everything immediately after the move, I am wondering how to best prepare and store the Brimnes furniture to prevent any damage during storage – especially concerning moisture, warping, or scratches.
Specifically, I am interested in:
- Should the furniture be disassembled or left partially assembled?
- What surface care or protective measures are recommended?
- How should the pieces be transported to ensure they remain intact?
- Are there common issues that particularly affect the Brimnes models?
I appreciate any experience or tips that can help store the furniture safely with minimal wear.
Thanks in advance!
Thanks in advance!
This question is very relevant because the Brimnes series mainly consists of coated particleboard, which is susceptible to moisture and mechanical stress.
I recommend a complete disassembly for several reasons:
- Individual parts can be stored more efficiently and take up less space, reducing unnecessary stress on the furniture components.
- Screws and small parts should be collected in labeled bags and ideally attached to their respective parts (e.g., with tape).
Before storage, the surface should be thoroughly cleaned of dust and dirt, preferably with a slightly damp microfiber cloth, not wet. Afterwards, I recommend a dry and well-ventilated environment to prevent moisture from penetrating the edge banding of the particleboard.
To protect against scratches, parts can be placed on cardboard, blankets, or foam; direct contact with laminate or concrete floors should be avoided.
Regarding transport, please do not rest furniture pieces on edges or hinges, as these areas are prone to damage. Instead, transport items flat with sufficient padding to avoid deformation or pressure marks.
Is there a storage room with climate control, or just a regular basement? This information would help provide more precise recommendations.
bapar schrieb:
Is there a storage room with climate control, or just a regular basement? That would be useful for more precise recommendations.Thank you for the detailed information! The storage room will be a dry basement without active climate control, so the temperature fluctuates somewhat, but humidity is generally low. The base is a concrete floor with some dust, and the ceiling height is limited.
Are there specific padding materials that work particularly well to protect furniture parts effectively against abrasion and pressure marks? Sometimes I also read about bubble wrap versus blankets or simple cardboard.
As a supplement to the previous posts:
I recommend the following specific protective measures when storing Brimnes furniture in a dry basement with a concrete floor:
- Use soft blankets or felt pads under the furniture pieces. Cardboard is better than nothing but can weaken due to moisture.
- Bubble wrap protects against scratches, but the wrap should not be airtight around the furniture, as condensation can form.
- Ideally, wrap the furniture in breathable fleece, adding blankets and padding at contact points if needed.
- Lay the furniture parts and boards flat on top of each other to prevent warping; do not stack heavy objects on them.
- For cleaning before storage, microfiber cloths with mild detergent or simply dry wiping are sufficient.
This way, the risk of moisture damage and visual blemishes can be minimized.
I completely understand why people worry about storing their furniture. I moved some Brimnes dressers last year and unfortunately didn’t fully disassemble them, which caused minor damage to the edges.
It definitely makes sense not to use the wrap airtight; I should have thought about that beforehand as well. I would definitely recommend preparing the furniture in a way that avoids stress when you’re short on time, as that helps prevent poor decisions.
Are there any experiences regarding how long Brimnes pieces can be stored without quality loss? I imagine that’s tricky with particleboard.
Blavin schrieb:
Bubble wrap protects against scratches, but the wrap shouldn’t be sealed airtight around furniture as condensation can form.
