O
OnClayton21 Jan 2015 18:37Hello everyone, I have a detailed question about repainting Malm wood surfaces, which are often quite sensitive to changes. I own a Malm dresser at home that has been repainted several times and now shows some peeling and uneven areas. I’m particularly interested in how to approach repainting without damaging the surface texture or the original finish. Specifically: what preparation steps are important (sanding, cleaning, priming)? Are there certain paints or varnishes that should be avoided, and are there special techniques to achieve as seamless a transition as possible? I would also appreciate tips on appropriate drying times and how to prevent dust inclusions. Thank you very much in advance!
This is a really important and never entirely straightforward topic when it comes to touching up Malm wood surfaces, so thank you for addressing it so explicitly. It often feels like walking on thin ice because the surface already has its original coating, and any carelessness will be visible.
First, a tip for preparation: I would always start by thoroughly cleaning the surface, preferably with a mild dish soap and a soft cloth to ensure no grease residues remain. Then, lightly sand with very fine sandpaper (e.g., 320 grit) to improve adhesion, but not too deeply to avoid damaging the texture.
Primer should only be applied if the paint is visibly peeling or the surface appears porous. Otherwise, a suitable Malm paint is often sufficient for touching up.
In my experience, you need to handle the paints very carefully: water-based paints designed specifically for furniture are best. Also, applying multiple thin coats instead of one thick coat yields a better finish with less risk of drips or streaks.
Regarding drying times: it’s better to wait longer, especially in rooms with poor ventilation. You can avoid dust inclusions by working in as dust-free an environment as possible and thoroughly removing dust after sanding.
I hope this helps you! 🙂
OnClayton schrieb:
Which preparation steps are important (sanding, cleaning, priming)?
I would go into much more detail when repainting Malm wood surfaces, especially because this topic involves many potential pitfalls.
First, it is important to carefully assess the exact condition of the surface before starting. Not every area requires the same treatment. Where the old paint layer is intact, you should only sand very gently to ensure the new paint adheres without exposing the bare wood and altering the appearance.
Here, it is recommended to use furniture and wood paints that have high elasticity and adapt well to the existing layer. For Malm furniture, these are usually water-based acrylic paints, as they do not swell or shrink significantly, keeping the surface stable.
Regarding the procedure:
1. Cleaning: Before sanding, clean all surfaces with a dust-free cloth and a mildly alkaline cleaner to remove oils and dirt.
2. Sanding: Gently scuff the surface by hand using 320 to 400 grit sandpaper—avoid aggressive sanding! This creates a fine texture for the new paint to adhere to.
3. Dust removal: After sanding, make sure to remove the dust with a damp microfiber cloth or a tack cloth, as any remaining dust will cause unevenness.
4. Priming: Apply a primer specifically matched to the furniture on any chipped or bare areas to ensure uniform absorbency.
5. Applying paint layers: Allow long drying times per coat (at least 12 hours), and lightly sand between coats to ensure perfect adhesion.
Sometimes touch-ups look better if the transitions are carefully blended with a very fine sponge or brush to avoid abrupt edges.
Have you already tried which paint brands are available in your region? This can greatly affect the result, as quality differences are really noticeable.
OnClayton schrieb:
Are certain paints or coatings not allowed, and are there special techniques to achieve the most seamless transition possible?
Rashadmeo22 Jan 2015 19:42Wow, what great and in-depth tips already shared here! It really motivates you to keep working on the Malm dresser yourself! 🙂
I just want to add that it helped me a lot to go over the surface once more with a damp, lint-free cloth after sanding and cleaning to catch all the fine dust particles. Especially with Malm, the surface is so smooth that even small dust particles become very noticeable.
This is really the key point! I once applied the coat too thickly and didn’t sand – unfortunately, the result was very uneven. With a bit of patience, though, it turns out really nice.
By the way, for my last touch-up, I used a finer brush instead of a foam roller – this gives you much more control around the edges and creates a great finish.
Good luck and don’t get discouraged, it’s definitely worth it! 🙂
leebi7 schrieb:
Lightly sand between the coats to create a perfect bond.
