I am currently planning the installation of the baseboards for my new IKEA Metod kitchen project and have some uncertainties about the best way to secure the baseboards so that they remain stable and properly fitted even after several years. I am especially interested in tips on preparing the substructure, precise alignment, and dealing with floor unevenness.
I have also read that special clips or screws are needed for the Metod baseboards – could you share your experience on which fastening materials work best?
Are there any particular details to keep in mind when fitting the baseboards at corners or door openings? I want to avoid unsightly gaps or stresses later on.
It would be great if you could share your experiences, common pitfalls, or clever tricks related to installing IKEA Metod baseboards – including any advice on tool usage!
Thanks in advance for your help!
matthewon21 Jan 2016 21:44To be honest, the IKEA Metod baseboards are a typical example of “adequate, but nothing special.”
Here, I would even suggest a radical approach: if the floor is very uneven, the prefabricated alignment system won’t help much. Sometimes it’s better to cut the baseboards to size yourself or add small shims separately, instead of relying blindly on the supplied clips.
The fastening materials? Using only IKEA’s clips is a no-go, mainly because of durability. My recommendation would be to use screws and anchors (depending on the substrate) and either use the clips just for appearance or skip them entirely.
As for the corners: the prefabricated corner pieces are often over-engineered and don’t fit perfectly, so it’s better to do minor adjustments or mask the joints with a bit of silicone.
In short: the best results are achieved not by blindly using the IKEA kit, but with a bit of practical craftsmanship.
Nusutan schrieb:
What’s especially important to me are tips on preparing the substructure, precise alignment, and dealing with uneven floors.
A very sensible question and a solid approach, Nusutan! I’m happy to explain how I handle baseboards with IKEA Metod, especially focusing on the technical aspects.
First, regarding the preparation of the substructure: It is crucial that the baseboard surface is clean, even, and free of dust and grease.
- Irregularities are best compensated for using small wooden wedges or adjustable baseboard feet. The adjustable feet (a kind of height-adjustable cabinet foot) allow for perfect alignment of the baseboard.
- For fastening, I use the original clips, but I supplement them with additional small screws to prevent wobbling under load.
- Corners are most precisely cut with a miter cut. For this, a miter saw is recommended — a handsaw with a miter guide is sufficient if used carefully.
- If the wall is not square, applying a angle tool or adjusting with a sanding block helps to ensure the baseboard fits flush.
Tool tips:
- Miter saw or fine handsaw
- Cordless drill with bits
- Tape measure and spirit level
- Sandpaper or sanding block
One more note: Installing the baseboards is ideally done after all flooring work is complete but before the kitchen units are installed, as this makes any corrections easier to carry out.
If you find baseboards slipping frequently, I recommend additionally applying spots of construction adhesive on the back of the board — this secures it further without affecting the appearance.
I’m happy to answer any more detailed questions about your floor situation or the tools.
Tool tips:
This topic is definitely not as simple as it might seem at first glance. I personally faced some challenges with my Metod kitchen early last year.
I think that statement is spot on – the baseboards are functional, but installing them requires some patience and a delicate touch.
What was especially important for me was precise alignment: before screwing, I used small wedges at the wall joints and corners to ensure nothing was pressing or gaps formed. And honestly – even if it’s annoying, it’s better to measure and cut twice than to do it poorly once!
I tried the tip about adding extra screws and can confirm that it really improves stability.
Regarding tools – definitely go for a fine hand saw or a miter saw, as that makes cutting much easier. At first, I struggled with a regular saw and got quite frustrated.
If anyone has questions about installing on specific floorings like tiles or laminate, I’m happy to help.
matthewon schrieb:
The IKEA Metod baseboards are actually a typical example of “adequate but nothing special.”
