ᐅ When is the earliest time to start painting work?
Created on: 23 Mar 2020 21:25
Andre77
Hey,
from when is it possible to start the painting work in the finished living area (FLA)? Do certain drying processes need to be waited for? For example, only after the screed heating phase, or is that not relevant?
Thanks!
Andre77
23 Mar 2020 22:29
You ask a simple question and get treated like crap, thanks a lot....
If you have nothing to contribute, then just keep quiet.....
Nordlys
23 Mar 2020 22:45
Painting is done once the interior plaster and screed are dry. There are three steps: filling, sanding, and painting or rolling. Alternatively, wallpapering can be done, which reduces the amount of filling required.
The flooring is installed last. The door frames should already be mounted before painting, as they need to be worked around.
Andre77
23 Mar 2020 22:58
I just want to apply a textured render on it. Knauf Easyputz. Do you also need the Knauf primer? Or is the primer the same as a deep primer, meaning other products could be used as well?
Nordlys
23 Mar 2020 23:20
Stay within the system and use the one from Knauf.
Andre77
23 Mar 2020 23:26
All clear. Thank you, Karsten
fach1werk
1 Apr 2020 08:19
I find it advantageous to work from top to bottom, starting with the ceilings. Before applying filler, if filling is necessary, you should first run a trowel lightly over the surface to lift any high spots. Check surfaces in raking light beforehand.
I think finishing the surfaces is satisfying work because you can clearly see the results.
Enjoy the process,
Gabriele
