ᐅ Experience with Timber Frame Walls 16–24 cm Thick
Created on: 3 Feb 2018 11:05
Meister_Lampe
we are currently looking for a prefabricated house manufacturer that suits our needs.
The house will most likely be built using timber frame construction.
I have some concerns about the differences in the walls.
One manufacturer builds 16cm (6.3 inches) thick wooden walls, while another uses 24cm (9.4 inches) thick ones (insulation and drywall not included).
The thinner wall is said to have a better U-value, which I could possibly explain technically due to different insulation.
What really worries me is the structural stability. Is a wall with a 16cm (6.3 inches) timber frame significantly less stable?
Does anyone have experience or information about the differences between these types of walls?
stefanc84
4 Feb 2018 17:32
Yes, I understand that, and such timber houses do exist. The major manufacturers often rely on slim and cost-effective wall constructions using expanded polystyrene (EPS). However, there are many different construction methods for timber frame structures – and naturally, everyone believes their approach is the best. There are definitely good options for sound and heat insulation with timber as well. The indoor climate should generally be noticeably better than in a masonry house built according to energy-saving regulations with external wall insulation systems (EWIS).
Nordlys
4 Feb 2018 18:14
But the highlight doesn’t have an external thermal insulation composite system (ETICS), it uses the premium option. Brick cladding, insulation—probably Rockwool or something similar—then bricks.
blackm884 Feb 2018 19:21
Wood cracking?! Yes, I suspect this is due to the difference between outdoor and indoor temperatures or the humidity levels. So far, we haven't experienced cracking, but I am familiar with it from other houses. Wood expands and contracts, unlike concrete and stone.
Wall construction always varies, but the neighboring houses are well insulated. Usually, most of the heat comes in through the windows... at least in our case.
