ᐅ Timber frame construction
Created on: 30 Jan 2013 08:10
Hello, I have a question about timber frame exterior walls.
The plan is to insulate between the studs with mineral wool. The interior sheathing will be stiffening OSB. On the outside, direct cladding on the wooden studs was planned using Bluclad. Now, an external ETICS (External Thermal Insulation Composite System) is possibly being considered.
However, I can’t find any ETICS systems designed for timber frame walls with mineral wool insulation. I only find systems using insulation materials made from wood fibers, hemp, or similar.
I would like to stick with mineral wool.
I would appreciate any advice.
U
Urs1988-1
14 Jan 2016 12:15
We are satisfied so far. I pay about 300 francs per year. I think that is reasonable. If there are any problems, they respond quickly as well.
Thank you very much
Roman-1
5 Mar 2016 08:05
Urs1988 schrieb:
So far, we are satisfied. I pay about 300 Swiss francs per year. I think that’s reasonable. If there are any issues, they respond quickly.
Many thanks
I believe this was meant for a different topic. This discussion is about a timber frame wall for the exterior. In this area, mineral wool insulation is not used for external thermal insulation composite systems (ETICS / EIFS). Different materials have to be used here.
