last year we renovated our upper floor using a timber frame construction. The wall assembly from inside to outside is as follows:
2 layers of gypsum board
Counter battens / installation space
18mm (0.7 inch) OSB board, tightly glued
200mm (8 inches) mineral wool with a thermal conductivity of 0.035 W/mK between the studs
My question is whether the outer OSB board might be a potential weak point regarding mold growth—possibly because it is too airtight? If so, how could this issue be addressed?
Perhaps additional external insulation?
Or should it simply be removed again?
I would appreciate any constructive advice.
basically, you should really have a professional on site calculate the whole thing...
Installing a vapor barrier retrospectively is not exactly cost-effective either. The cladding and installation layer would have to be dismantled again. Besides, there is always a difference between theory and practice. In theory, it might work with a vapor barrier, but who supervises the work and ensures the membrane is installed correctly? I consider this solution to be risky.
The wall’s bracing is most likely provided by the inner OSB board. I would assume that the outer OSB board has no structural function. The wall build-up is incorrect, and I don’t think the structural engineer accounted for it this way.
Cost for a wood fiberboard: I would estimate around 15 to 20 euros per piece (if you install it yourself), but I’m not one hundred percent sure. Your carpenter can probably give you more precise information.
