ᐅ Vapor Barrier Tightness in New Construction: Are Screws a Problem?
Created on: 20 Feb 2018 13:40
Skyfire
Skyfire
20 Feb 2018 13:40
I’m back again. Our regional and preferred provider would build us a timber frame wall with mineral insulation.
This construction method is new in their offer.
It would include a fiber-reinforced paper vapor retarder, followed by an engineered wood panel, and finally a gypsum board.
The assembly would be:
60mm (2.4 inches) mineral insulation
240mm (9.4 inches) timber studs
240mm (9.4 inches) installed insulation
Paper vapor retarder
Engineered wood panel
Gypsum board
Are there any considerations regarding airtightness, especially related to screws, nails, and the vapor retarder?
I definitely want to prevent moisture from entering the wall and insulation.
Thank you very much.
Sky
Skyfire
20 Feb 2018 14:59
I made a typo!
First comes the wood-based panel, then the vapor retarder, and finally the drywall.
So: 12mm (0.5 inch) wood-based panel
12.5mm (0.5 inch) drywall panel
How long should the screws be when mounting objects?
