ᐅ Thermal insulation system installed on a dry basement floor in an older building
Created on: 12 Nov 2025 22:51
Sir Toby
Sir Toby
12 Nov 2025 22:51
our house was built in 1963 and still has the original walls, meaning that no insulation panels or similar materials have been installed either on the outside or inside so far. It has a full basement, and one of the basement rooms is heated.
In this room, I want to install thermal insulation on the basement floor. The current ceiling height is 2.20 m (7 ft 3 in). The planned insulation setup will be about 8 cm (3 inches) high, leaving roughly 2.12 m (6 ft 11 in) of headroom.
Important info: the basement is dry!!
My idea for the floor construction from bottom to top is as follows:
  • Concrete slab (definitely without any protection against cold or moisture). But as mentioned above, the basement is fortunately dry.
  • Screed (thickness unknown and not relevant to me)
  • Vapor barrier foil
  • Battening 30 x 50 mm (1.2 x 2 inches)
  • EPS boards (more vapor permeable than OSB3, in case moisture should come from below)
  • Cork laminate flooring
Is this feasible without causing issues with moisture or mold later on?
I am also considering filling the battens with loose perlite insulation. Does this make sense at an insulation thickness of about 35 – 40 mm (1.4 – 1.6 inches)? Would there be any noticeable difference, or is the air already insulating well enough?
I would appreciate informative answers very much.
Counter-questions or suggestions are also very welcome.
Thank you!!
Nauer
12 Nov 2025 23:19
Hi Toby,
Your proposed construction method sounds reasonable at first glance but has a few minor pitfalls you should definitely keep in mind. If the basement floor is uninsulated and without waterproofing from the 1960s, you are currently lucky that it remains dry, but this can change once you add a thermal insulation layer above. This shifts the dew point downward – and that often causes condensation under the vapor retarder, even if the concrete previously showed no signs of moisture.
The battens on the membrane are also tricky: wood on a membrane always means that any trapped moisture might no longer be able to dry out. If you really want to use battens, then only with a capillary-breaking layer beneath or better yet, a system that avoids air gaps entirely. In your case, a compressive insulation material (e.g., XPS or PUR) with a dry screed or laminate flooring on top would be the safer solution – no air gap, no perlite, no risk.
The perlite infill between the battens, at 3–4cm (1–1.5 inches) thickness, honestly offers hardly any measurable improvement. Air insulates nearly as well at this thickness, but you introduce additional unevenness and the risk of settlement.
I’m curious: why do you want to work with battens at all instead of going directly on a compressive insulation? Is it only because of the total build-up height or due to possible wiring/plumbing underneath? Because that determines whether your concept with the membrane even makes sense.
Good luck
Sir Toby
13 Nov 2025 22:13
Thank you for the quick response!
Why do I want to use a vapor barrier and battens?
The existing screed is almost level since it is undamaged, but with the battens, I wanted to achieve maximum evenness. I also imagine that a construction with battens plus subfloor panels is more stable than loose-laid rigid foam boards (PUR/PIR). There are no cables or pipes on the floor.
The vapor barrier was recommended to me by an acquaintance to prevent any moisture from reaching the construction above.
I have also considered PUR/PIR. However, I am concerned that the boards could shift, creating gaps, which could transfer the load entirely to the laminate layer above and potentially cause damage.
There is also the issue of point load. For example, if I have a point load of 1 kN, can rigid foam boards withstand that?
If I use PUR/PIR, should the installation fit tightly against the walls, or can it be laid almost floating with only minimal contact or even some air gap at the edges? How are PUR/PIR boards typically installed? Are they laid loose, glued, or fixed by other methods?
Installing the boards is certainly less work compared to using vapor barrier, battens, oriented strand board (OSB), and laminate. That would be another advantage for the boards. However, I have concerns about surface evenness, as described above: the screed is undamaged and “fairly” level but not perfectly so. The differences range between 4 and 10 mm (0.16 and 0.39 inches) measured with a 2-meter (6.6 feet) straightedge. The 10 mm (0.39 inches) difference only occurs towards one wall. At the other edges, the differences are about 4 mm (0.16 inches). The floor surface within the room is practically even.
A rough cost estimate shows that the PUR/PIR solution is somewhat more favorable financially.
What would be the best choice here in terms of building physics?
