ᐅ Thermal bricks / Poroton and insulated facing bricks – Is this the optimal solution?
Created on: 8 May 2018 23:05
Hausbauer1
A colleague of mine is planning to have his house built soon using thermal bricks/Poroton combined with insulated facing bricks. Since discussions about wall constructions here often become almost like a religion, I wanted to open this up for discussion to see whether this might be a good solution.
The thermal insulation of this combination is said to be excellent. It is also supposed to be a solid choice regarding soundproofing, protection against summer heat, costs, vulnerability to construction defects, weather resistance, and appearance. But doesn’t everyone say that about their preferred system?
Alex85 schrieb:
Building materials with high density provide good sound insulation.All building materials have poor sound insulation if they are incorrectly connected to other components.https://www.instagram.com/11antgmxde/
Knallkörper schrieb:
The ideal wall structure for me would be: sand-lime brick - mineral wool insulation - facing brickwork.I also consider a cavity wall construction to be the best in terms of quality. However, I would not choose mineral wool for insulation. It only has idealistic advantages over EPS and otherwise only disadvantages, especially regarding cost and susceptibility to moisture.
Knallkörper3 Jun 2018 00:01I wanted the exterior to be more vapor-permeable, which is difficult with EPS but not a problem with mineral wool. So far, our insulation layer is dry, so I don’t expect any issues *knock on wood*
Hausbauer13 Jun 2018 19:35In theory, I would agree with you on the double-shell wall construction. Unfortunately, it seems that construction errors occur much more often with double-shell systems, and the additional costs should not be underestimated.
For the double-shell option, I would use thermal bricks, PUR (polyurethane), and bricks.
