Hello everyone.
A quick overview of the system.
Air-to-water heat pump Elco with underfloor heating, 9.93 kWh (kilowatt-hours) photovoltaic system, and central ventilation with heat recovery.
I have now removed the electric actuators for the hydraulic balancing and plan to run the system this way over the winter. I want to make the balancing adjustments using the "float valves." In which direction should they be turned to increase or decrease flow? Is there anything I should be aware of?
Currently, the settings are as they were for the hydraulic balancing.
The heating curve is set to 2 out of 10, and the reference outdoor temperature is set to 12°C (54°F).
So at the moment, heating only runs at night.
The delay time is set to 5 minutes. After this time window, the heating switches off if the temperature is above 12°C (54°F) and switches on if below 12°C (54°F). Would you recommend changing this value?
First of all, it is actually still too warm for any balancing.
Secondly, do you know what the balancing affects, etc.? T_im_Norden has a great explanation here. Have you read it already? https://www.hausbau-forum.de/threads/zentraler-raumtemperaturregler-fuer-err-der-fbh.35503/page-7#post-417304
Thirdly, simply remove the actuators first and wait for 3 to 4 days to see what happens. It is advisable to avoid adjusting anything during this time.
Interventions after a previous hydraulic balancing rarely involve more than +/-0.25 to 0.5 turns on the valves in the heating circuit distributor.
