ᐅ Window won’t open anymore – how to fix it?
Created on: 16 Oct 2023 15:56
Ruediger60
Ruediger60
16 Oct 2023 15:56
Close-up of a metal door frame with rust stains and rubber sealing.
11ant16 Oct 2023 17:50
Ruediger60 schrieb:
One of my windows unfortunately broke, [...] The window is from the company K..l
Windows are very rarely from just one company. Typically, the end user knows the name of the profile manufacturer but does not know which fittings and mechanism the window installer used to assemble the complete product. From your description, it seems you made an operational error that could be enough to "misalign the timing" of this "gear system," so to speak—but no extreme force was applied that would cause permanent damage. You will need to call a specialist for window installation—most likely from the supplying company. You will have to endure sympathetic noises from the mechanism during the repair without anesthesia. You will probably have to part with two green bills and be patient for a two-week delivery time. I expect a difficult process, but both the “mother and child” will get through it well. Said as a former window manufacturer and later dealer (but not an installer) speaking.
Ruediger60
16 Oct 2023 18:17
Thank you very much for the information. Above all, I am glad that a professional responded to me. I had forgotten to mention that the top part of the window can still be opened slightly, which might possibly offer a chance to work on the mechanism that is still accessible there. Would that be feasible? Thank you.
11ant16 Oct 2023 18:24
Ruediger60 schrieb:
Many thanks for the information. Above all, I’m glad that a professional responded to me.
Let’s rather say “semi-professional,” since I never actually trained as a window installer.
Ruediger60 schrieb:
I forgot to mention that the window can still be slightly opened at the top; in this way, there might be a chance (?) to work on the mechanism, which is still accessible there.
The professional—ideally from the company that originally installed it—will need to examine an identical model and then inspect the affected window to find out how it operates. Patience and skill will be their most important tools, followed by replacing any bent parts.
Ruediger60
16 Oct 2023 18:25
OK, I will do it exactly like that. Thanks again!
