Hello everyone, I have had the IKEA Malm bed at home for a few weeks now, but I noticed that the bed starts to rock or wobble slightly even with light pressure or movement. Since I prefer to sleep on a stable and secure bed, I am wondering what options there are to stabilize the Malm bed.
I understand that the frame is made of wood and has a rather simple design, but I wanted to know if anyone has practical tips on how to reduce or completely prevent the rocking without having to carry out extensive modifications. My concern is that the rocking movement might not only become uncomfortable over time but could also be damaging to the construction.
So far, I have checked that all screws are tight and also verified the position of the slatted bed base, but the rocking remains. Are there any aids or simple tricks that can increase stability?
I look forward to helpful suggestions and thank you in advance!
Hello rabih,
If your Malm bed still wobbles despite checking all the screws, it often comes down to the connection points or missing contact between the frame and the slatted bed base. A common reason is that the screws are installed but not fully tightened, or the slatted base can be slightly moved.
A good first tip is to completely loosen all screws on the frame and then retighten them firmly using a good screwdriver or cordless drill—sometimes the issue is uneven tightening.
Additionally, you can attach small rubber or felt pads to the contact surfaces facing the floor to prevent slipping and make the bed stand more securely. Some users also recommend installing angled metal brackets inside the corners to stabilize them, in case the frame itself shifts slightly under load.
Inserting wooden wedges where there is play can help as well, but be careful—not too much pressure to avoid damaging the wood or stripping the screws.
If the slatted base support doesn’t fit perfectly, it can also help to place thin rubber pads under the corners to prevent the base from moving.
Remember to rotate or swap the slatted base after stabilizing if one side was loaded unevenly.
If you want, I can send you a small step-by-step guide on how I stabilized my own Malm bed. 🙂
rabih schrieb:
So far, I have checked whether all screws are tight and also verified the position of the slatted bed base, but the wobbling remains.
Hello rabih!
I know your problem all too well :-) The Malm looks really stylish, but it isn’t always very sturdy right out of the box.
I can only agree with that; it makes a big difference.
Another common issue is the black plastic pads under the frame. Sometimes they’re too smooth, causing the bed to slide or wobble on the floor when you move. Just sticking some non-slip pads in between often helps!
By the way, if you shift the mattress slightly, it already helps to distribute the weight better – I know it’s not a permanent fix, but useful in the meantime.
If you’re like me and like DIY projects: I recently got some small angle brackets and screwed them under the corners. They act almost like reinforcements, and just like that, the wobbling was gone.
Good luck with stabilizing it – and feel free to share what worked best for you! 😉
Tevin schrieb:
A good first tip is to completely loosen all the screws on the frame and then tighten them again firmly with a good screwdriver or cordless drill
Good morning rabih,
I would like to suggest a structured approach to systematically improve the stability of your Malm bed:
1. Check screw connections:
- Carefully loosen all screws of the bed frame (including cross and longitudinal connections)
- Inspect the screw holes for any signs of wear or damage, which can cause looseness and wobbling
- Then tighten the screws evenly but firmly, preferably using a torque screwdriver or a good cordless drill with torque control
2. Add reinforcements:
- Metal brackets (corner braces) installed on the inner corners of the bed frame significantly reduce vibrations
- Make sure to use appropriate brackets with pre-drilled holes to prevent the wood from splitting
- Small wooden battens glued and screwed on the sides can also add extra stability
3. Optimize contact points with the floor:
- Non-slip felt pads or rubber pads on the bed legs improve grip and prevent sliding
- Check that the legs are securely fixed and do not wobble
4. Check the slatted frame:
- The slatted frame must sit firmly and should not rattle
- Spacer pads between the slatted frame and the frame help prevent unnecessary movement
Common issues I often see include applying too much or too little torque on the screws or using overly tight brackets that damage the wood.
In summary: The combination of tightly fastened screws, additional metal brackets, and non-slip contact points reliably ensures the desired stability for Malm beds.
If you like, I can also provide some sources for suitable corner braces and rubber pads. Good luck with your project!
