Once again, I need to ask for help here. This time it’s about our kitchen, which unfortunately doesn’t seem to have a good outcome.
Now to the actual story:
In 2015, we moved into a newly built apartment for rent and purchased a new Nobilia L-shaped kitchen for €8,000 (approximately $8,700) and had it installed. In mid-2017, we signed our house construction contract and immediately went to a kitchen design studio to ask if we could dismantle our 2015 kitchen, modify it, and reinstall it in the new house. Unfortunately, the kitchen studio where we bought it in 2015 had gone out of business, so we had to find a new one.
Anyway, we emailed the house floor plans and the documents for our 2015 kitchen in advance and arranged an appointment. At the meeting, we were told that the kitchen could be extended and that the matching furniture pieces were still available to order as before. They then showed us a proposal we liked. However, they said that a 60cm (24 inches) cabinet we already had would be left unused because it no longer fit. IMPORTANT!
So far, everything seemed fine, and we signed a contract for €3,000 (approximately $3,300) covering dismantling, transportation, and installation, with a deposit of €1,000 (approximately $1,100).
In July 2017, we moved into the house and the kitchen was installed right away. Unfortunately, we were only partially present during the installation because it was moving day. In the afternoon, the kitchen installer asked if we knew that according to the plan a 60cm (24 inches) cabinet would be left unused. We said yes, because their manager had told us it wouldn’t fit anymore. It turned out that it actually did fit and there was about 10cm (4 inches) of space left up to the window. When we asked if he could still install it, he said no, because the countertop and backsplash had already been glued and mounted.
We immediately called the studio, and we were told that to install the cabinet now, the entire countertop and backsplash would have to be replaced. Therefore, they wanted to charge us about €1,500 (approximately $1,650) extra. When we asked why the cabinet wasn’t planned for originally, they just said we knew that but couldn’t remember why it wasn’t to be installed. We refused the €1,500 offer right away and told the installer still in the house. He said he could do it cheaper by just adding a piece to the countertop and backsplash. This would leave a visible seam on the surface, but material costs would only be around €300 (approximately $330). We agreed, and the installer made arrangements with the studio manager.
In October, the installer came back and started working. He noticed that due to a corner outlet he had installed himself, there was now a large hole in the countertop and backsplash right in the middle of the kitchen. We obviously told him that we could not accept this. He tried to find a solution and offered to get the same model as the corner outlet but not for the corner, so it could be mounted over the hole. We agreed, trusting that he would properly install the right outlet.
On Friday morning he came again, but unfortunately, we were at work and my parents let him in. When we got home Friday evening, I just heard my wife say loudly, “Are they serious?” Pictures are attached.
We immediately dismantled it ourselves and have not paid the remaining €2,300 (approximately $2,530) invoice that was left behind.
Does anyone have any idea how I can best get out of this situation?
I will definitely not pay the remaining amount because I will not accept the kitchen as it is. The agreed-upon power strip looks nothing like the others and is also damaged, with one screw missing on the side. It was only meant to be a temporary compromise for the installer. The installer himself seemed to think we wouldn’t accept it either, as he only attached the outlet with one of two screws, probably to avoid drilling another hole.
I also saw in the old email exchange that the floor plan we sent did allow for the 60cm (24 inches) cabinet from the beginning, but the planner simply overlooked it, and we were too naive not to check it ourselves (we were in the middle of the construction phase). Because of this one cabinet, we now have all these problems. I never thought the kitchen would be the most complicated trade of the entire house.
A lot of text, a lot of confusion. I just don’t know what to do. I can only reach the kitchen studio again on Tuesday and am simply asking for your advice on how to best respond here. 🙁
Regards
Regards
chand198626 Nov 2018 08:36Oh dear, I'm sorry to hear that.
It’s obviously inconvenient for you that it was visible in the plan, since it officially meant you knew it could fit if someone wanted it to. 🙁
I don’t quite understand the situation with the sockets. Sure, having two power strips isn’t ideal, but isn’t that better than having the cable exposed and a hole in the panel?
And: why was this corner socket installed in the first place? There wasn’t even a cabinet there before, and only the other socket was there. Couldn’t it have just been left like that?
chand1986 schrieb:
Oh no, I’m sorry to hear that.
It’s unfortunate for you that this was shown in the plans because it means you officially knew it could fit if you wanted. 🙁In the kitchen layout included with the contract, this was not visible. The plan ends directly at the cabinet.
chand1986 schrieb:
I don’t fully understand the issue with the power outlets. Sure, having two strips isn’t ideal, but isn’t that better than having the cable exposed and a hole in the countertop?
And: Why was this corner outlet installed in the first place? There wasn’t a cabinet there before, only the other outlet. Couldn’t it have been left as it was?We agreed to the outlet solution because we preferred it over having an open hole. However, the strip looks different from the other outlets (different material, height, screws, etc.).
The holes are there because previously the tall cabinet on the right connected there, and the small corner outlet was installed in that spot.
chand198626 Nov 2018 08:53For better understanding: The tall cabinet was shifted to the right, and your 60cm (24 inches) unit was placed in between?
And actually, it only requires a visually proper and neatly installed power strip where the corner socket used to be, and then the issue is resolved?
Yes, exactly. That’s how it is.
Apparently, the model we have in the corners is not available for the regular wall. However, the installer said he would install the suitable one there. He probably didn’t know any better himself.
I have already considered buying the corner socket again and simply installing it between the countertop and the backsplash panel, but unfortunately, there are also two screw holes at the top 🙁
chand198626 Nov 2018 09:11Is there no manufacturer offering corner and straight solutions from the same series? In that case, simply replace both molding strips and that will do.
