ᐅ While children were climbing on it, the Kallax tipped over – how can this be prevented?
Created on: 5 Apr 2022 10:37
Perikles53
Perikles53
5 Apr 2022 10:37
I have the following problem and hope for helpful tips: While children were climbing at home, a Kallax shelf tipped over because the little ones climbed on it. The shelf was not attached to the wall and stood freely, which ultimately caused the accident. I want to avoid this risk in the future without completely giving up the furniture – it should still serve as storage but be child-safe.
Are there practical methods or solutions to reliably prevent Kallax shelves (or similar furniture) from tipping over in a child-active environment? I would also appreciate hearing about experiences or products that have proven effective in practice.
I look forward to your suggestions and assessments.
gauvin37
5 Apr 2022 11:03
The shelf must be securely fastened to the wall. Using suitable brackets, anchors, and screws makes the Kallax very stable. Alternatively, floor clamp holders can be used. This is the simplest and safest solution.
bupar
5 Apr 2022 13:47
To prevent Kallax shelves from tipping over during use by children, I recommend always securing the furniture to the wall with anchors. These are usually affordable, easy to install, and provide reliable support.
Additionally, non-slip felt or rubber pads under the shelf feet can enhance stability, even if the unit is bumped. Locking individual compartments with child safety locks to discourage climbing is also an option.
In general, tipping accidents are mostly caused by a lack of proper anchoring. The shelf’s own weight combined with correct installation significantly reduces the risk.
JAFUHAU
6 Apr 2022 09:28
Perikles53 schrieb:
During children’s climbing at home, a Kallax shelf tipped over[...] I want to avoid this risk in the future without completely giving up the furniture – it should still serve as storage but be childproof.
I’m sorry to hear about the incident at your home – accidents like these can happen quickly and are especially dangerous for little ones.
Perhaps a combination of secure wall mounting and rearranging the surroundings could help: for example, reducing the height of objects stored on it or keeping heavy items in the lower compartments.
I think it’s important to stay patient, even when it’s stressful. Children explore their world often quickly and energetically, which inspires us adults as well. The environment should be safe but also enjoyable! 🙂
TEOZAR
7 Apr 2022 16:41
gauvin37 schrieb:
Make sure to secure the shelf to the wall.
This is absolutely the best advice. Additionally, I would like to highlight the following points:
1. The fixing materials should be adapted to the wall type: use toggle bolts for drywall and anchors with sufficient load capacity for concrete walls.
2. For very active children, it can be useful to secure the shelves at the bottom with base elements or to use a combined solution of wall and floor anchoring.
3. It should also be ensured that there are no overhanging objects or hard-to-reach elements that might encourage climbing.
If you are unable to install it yourself, I recommend professional help to avoid mistakes. Better safe than sorry!
