Hello everyone, I finally want to build on my plot and have shortlisted four homebuilders – but I’m struggling to decide because each has their own philosophy about the ideal wall construction.
Poroton brick, insulation, plaster, plus triple glazing
Probably a classic nowadays. The house is completely airtight. The walls cannot “breathe,” so moisture from inside the house cannot escape. A ventilation system is therefore mandatory.
Brick, mineral wool, air gap, brick facade, plus triple glazing
Walls are somewhat more “breathable,” but the companies still recommend a ventilation system.
36.5 cm (14.4 inches) Wienerberger thermal brick, plaster, no additional insulation, plus double glazing
The “Mercedes” among bricks, no additional insulation needed, walls can breathe, triple glazing is not necessary.
So, which company is actually right and offers the perfect wall?
I have removed the names of the providers because otherwise I would have had to move the post into the moderated forum.
Best regards, Bauexperte
Bauexperte
Bauexperte
Lebensprojekt schrieb:
Well, that's basically how the building biologist described it—he considers aerated concrete the devil of all masonry materials.Wouldn't a building biologist prefer wood anyway?
Lebensprojekt1 Jun 2015 22:53nathi schrieb:
Wouldn't a building biologist prefer wood anyway?That's exactly right! But we didn’t want, for example, a timber frame construction, which is why we didn’t proceed with the deal.
Lebensprojekt1 Jun 2015 22:57Bauexperte schrieb:
Aerated concrete requires more precise workmanship, whereas with hollow brick blocks the plasterer has to compensate for tolerances caused by the firing process. For us, the only important thing is that by using one type of block or the other, we can avoid using an external thermal insulation composite system (ETICS). So I have no preference for or against either.
Regards, BauexperteWell, our initial idea was aerated concrete on the outside and sand-lime brick on the inside.
When you’re still open to everything at the beginning, you always end up being pushed one way or another.
Lebensprojekt1 Jun 2015 23:17Another reason we switched to Poroton is that it was supposed to keep the house cooler. I will probably be proven wrong once again.
