ᐅ The hinges on my Kallax keep falling out – need help!
Created on: 27 Dec 2023 08:37
lumi52
I have a Kallax shelf from IKEA, and the door hinges keep breaking off. The screws don’t just come loose; instead, the plastic or the wood threads strip out, causing the doors to eventually become unusable. This has happened multiple times now, with several hinges failing within just a few months. My question is: what could be causing this? I imagine the material might be too brittle, or the load on the hinges might not be distributed correctly. Does anyone else use the same shelf and have a solution or advice on how to fix this problem permanently? I would like to know if there is a way to attach the hinges more securely or if there are alternative hinges better suited for this. Thanks!
DUVIN
27 Dec 2023 14:02
Use anchors or small wooden washers as a base. Do not overtighten the screws. Alternatively, modify or reinforce the hinges.
tutan
27 Dec 2023 15:17
Hi everyone! 🙂
Kallax is really convenient, but the doors can become a real hassle when the hinges give out.
Here’s what I did: reinforced the screw holes with small battens on the inside so the load isn’t just carried by the thin panels. If you do it carefully, no one can tell afterwards. Also installed sturdier hinges – the standard plastic ones are honestly quite fragile.
A little DIY project, but totally worth it. Have fun with the screws!
Curtis
27 Dec 2023 16:29
[quote=lumi52, post: f2m8q4, member: XXX]I also considered whether attaching larger metal plates to reinforce the hinge areas makes sense...[quote]
That is a valid approach, but you will definitely need precise tools and installation skills for that. Metal plates can redistribute the load, but they must be fixed properly and decoupled to avoid stresses that could further damage the wood.
I also wonder how high the load on your shelf actually is. How many opening cycles do you have per day? Mechanical wear on the plastic hinges might be the main issue, leading to material fatigue. In that case, I would rather recommend sturdy hinges or a complete replacement.
The cause should be clearly identified: material quality of the shelf, load on the hinges, installation errors, or incorrect hinges.
lumi52
28 Dec 2023 08:12
[quote=Curtis, post: t0h4z80, member: XXX]I’m also wondering how high the load on your shelf really is...You should clearly identify the cause...[quote]
Thanks for the hint, Curtis! I don’t open the doors very often—maybe a few times a day, which seems like normal household use. So the load trigger doesn’t seem very intense to me.
I suspect the material around the hinge cutouts more, as I often see small cracks in the plastic or chips around the screw holes.
First, I will reinforce the holes with wooden dowels—and maybe switch to more robust hinges if I can find ones that fit. I didn’t have exact values regarding the load influence, so thanks for that.
