ᐅ Sewer pipes were incorrectly installed in the foundation slab!
Created on: 21 Sep 2018 22:27
SkyfireHello everyone,
Our foundation slab was covered today, and I checked the measurements.
The external dimensions are all correct, but some of the wastewater pipes and empty conduits are slightly off from the planned positions.
About half of the wastewater and empty conduits for electricity/water in the garage are 5-8 cm (2-3 inches) away from the original plan, while others are only 1-2 cm (0.4-0.8 inches) off.
We are having a prefabricated house built, and I think the measurements should be as precise as possible, otherwise the pipes might end up outside the walls.
Do you think a deviation of 5-8 cm (2-3 inches) is still acceptable tolerance, or is that too much for a prefabricated house? Will the slab need to be chipped open and corrected? Is it even possible to easily fix such small deviations?
Thanks a lot
Sky
Thanks a lot
Sky
