ᐅ Shell construction company builds basement smaller than in the approved building plans
Created on: 28 Jan 2023 21:18
domino55
A shell construction company was commissioned to build the basement with in-situ concrete according to the existing factory plan (14.0 x 6.66 m (46 ft x 21.8 ft)). However, the company missed the dimensions and built the basement about 4 cm (1.6 inches) smaller. This applies to both the exterior and interior measurements.
Dimensions according to factory plan
Target house width: 6.66 m (21.8 ft)
Target width of basement concrete walls exterior: 6.525 m (21.4 ft)
Target width of basement concrete walls interior: 6.025 m (19.8 ft)
Actual width of basement concrete walls exterior: 6.48 m (21.3 ft) (-0.04 m (-1.6 inches))
Actual width of basement concrete walls interior: 5.96 m (19.6 ft) (-0.06 m (-2.4 inches))
I measured myself using various tape measures and a laser distance meter.
What should be done in this situation?
Price reduction due to smaller total area? If so, how much? Are there any standard tables or guidelines for this?
It is especially unfortunate that the house was built smaller on the narrow side (maximum size restricted by the zoning/land-use plan), where every centimeter counts.
This also has consequences such as the possible need to adjust the factory plan (staircase, adjacent walls, support columns no longer fit).
Cross-section of basement: concrete basement walls, interior dimension, sound insulation, waterproofing.
SoL
29 Jan 2023 03:20
Was the survey engineer part of the contract? Give us some details.
Content-wise, you won’t get much money out of this (except for marginal amounts). So, the question of damages is less important than how to proceed.
hanghaus2023
29 Jan 2023 09:14
In my opinion, there is little that can be done here. Your site manager probably overlooked this?
6.66 m (22 feet) can easily be measured precisely with a tape measure or folding rule. There is no need for a surveyor.
Mistakes happen. If the measurements are very important to me, I measure them myself.
Now to the solution. The staircase is probably located along the wall to the neighbor, so there should be no issue there. The masonry work above the basement can still be carried out as planned. The bricks just protrude a few millimeters further. If necessary, you could make the basement insulation slightly thicker. I would call that a win-win situation.
If the structural requirements for the brick do not allow it, then an L profile can simply be attached to the concrete.
hanghaus2023
29 Jan 2023 09:19
Please share the section drawing from the construction planning, showing the transition between the basement and the ground floor.
WilderSueden
29 Jan 2023 10:39
domino55 schrieb:
These are concrete stairs that need to be custom ordered in advance; otherwise, you lose a lot of unnecessary time.
Who ordered the stairs? You or the shell contractor?
SoL
29 Jan 2023 11:00
WilderSueden schrieb:
Who ordered the stairs? You or the shell builder?
I assume it was him, and since they have already been ordered according to the plans, he now has a problem.
But that’s just a guess, because he still doesn’t provide all the information (contractual relationship, etc.).
Tassimat
29 Jan 2023 13:06
Is there an architect, construction manager, or similar professional involved, or will everything be contracted out independently?
