ᐅ The compressible sealing tape between the window and the exterior wall is deteriorating.
Created on: 2 May 2024 20:45
Jimy3435The compressible sealing tape installed between the window and the exterior wall is gradually deteriorating. It is turning gray and becoming crumbly. I already had a professional come by, but they were unsure how to proceed. They suggested applying silicone over it, "although this is no longer a common practice," or alternatively leaving it as is and continuing to monitor the situation.
Does anyone else have any ideas?
MachsSelbst3 May 2024 00:35If the professional is at a loss, in 99.9% of cases they are either the "contractor" or not a professional at all.
MachsSelbst schrieb:
If the professional is at a loss, then in 99.9% of cases they are either the "contractor" or not a professional at all. Or some things can no longer be "properly" repaired. If you break a broom handle, the carpenter might be able to glue it, but it still won’t be fully intact.
