ᐅ Has anyone experienced the back panel of the KALLAX splitting after assembly?
Created on: 15 Dec 2024 08:37
Fation0
Fation0
15 Dec 2024 08:37
I recently bought a KALLAX shelving unit and wanted to assemble it. I noticed that the back panel splintered quite a lot during assembly. Specifically, it cracked in several places and the edges didn’t stay clean, even though I worked very carefully and used the supplied screws. I’m wondering if this is a known issue or if I might have done something wrong during assembly. Are there any particular techniques or tools that should be used to protect the back panel? Maybe someone here has had similar experiences with the KALLAX back panel and can offer tips on how to avoid this kind of damage. Thanks in advance for your replies!
koduga
15 Dec 2024 09:46
Hey Fation0,
"I've had the back panel on the KALLAX chip…" – unfortunately, I know this problem well. It’s really frustrating, especially when you put so much effort into assembling it. In about half the cases, it happened to me when I tried to attach the back panel without drilling pilot holes first – that can easily cause the wood to split.
Quote:
Fation0 schrieb:
"I worked very carefully and used the supplied screws."
Even if you were careful, drilling small pilot holes often helps because the material is relatively thin and less sturdy. Alternatively, you could use small nails, which usually put less stress on the back panel.
I hope this helps! Especially with shelves like the KALLAX, the material isn’t really designed for heavy strain, so it’s best to handle it with care. 🙂
Davidleo
15 Dec 2024 10:03
Hi Fation0 and everyone else!
That sounds really frustrating, but don’t worry! 🙂 I had the same issue once, and I found out that you just shouldn’t press too hard with the screwdriver, otherwise the material will split immediately. I actually think IKEA should make a better back panel – but hey, that’s IKEA style: affordable and sometimes a bit tricky!
Quote:
koduga schrieb:
"pre-drilling small pilot holes because the material is relatively thin and less stable."
I totally agree with that! I usually use a drill bit slightly smaller in diameter than the screws, and it goes much smoother.
So, don’t give up! You can do it! And don’t stress – we’ll get it done! 🙂
Jensson
16 Dec 2024 14:22
Hello Fation0,
to better address the issue of the splitting back panel in the KALLAX shelf unit, I would like to explain some practical tips for assembly that have proven effective:
1. Material quality: The back panel in KALLAX is typically a thin hardboard (MDF or similar), which is very sensitive to excessive pressure.
2. Pre-drilling: As already mentioned by koduga and Davidleo, pre-drilling is essential. It is recommended to use a drill bit with a smaller diameter than the screws so that the screw still holds firmly in the material.
3. Screw type: The supplied screws are usually thin and designed for this type of material; tightening firmly is enough, but avoid overtightening.
4. Alternatives to screws: For back panels, you can also use 10mm (0.4 inches) thin nails with round heads, which further reduce splitting.
5. Protective measures: Placing the back panel on a soft surface during assembly prevents additional stress.
Summary: To avoid splitting, a combination of careful pre-drilling, cautious screwing, and a suitable surface is recommended.
I hope these instructions help you with your assembly—not only for KALLAX but also for similar shelving units. If anyone has questions about the exact drill size or screwing technique, feel free to ask!
