ᐅ The Challenge of Choosing a Heating System
Created on: 9 Aug 2019 13:19
Nikitierchen
I am going to build a new house of about 150m² (1,615 ft²) and I have a difficult decision to make. I was offered the following options for heating:
1. Vaillant gas condensing boiler compact unit + solar thermal system + decentralized ventilation with heat recovery
or
2. Rotex 8kW air source heat pump + ventilation WITHOUT heat recovery and without solar thermal system
Both options are apparently almost the same price. I might even save money with the heat pump because I don’t need a gas connection. How would you decide?
At the moment, I am leaning towards the air source heat pump. Would that be the right choice?
Thank you in advance and please be kind. This is my first post.
Bookstar
9 Aug 2019 17:02
Actually, it’s simple. Rotex is junk and very noisy. I would avoid it. The same goes for decentralized ventilation—trust me, better not.
If you need to save money, go for gas and solar thermal. If possible, add a central controlled residential ventilation system, but only for comfort reasons.
And this recommendation comes from me, who has been reasonably satisfied with my air-to-water heat pump so far. I only chose it because we can’t have gas.
dab_dab
9 Aug 2019 17:50
same decision-making -
  • no gas, therefore heat pump
  • no horizontal ground collector due to granite in the soil
  • heat pump and ventilation systems separated
  • air-to-water heat pump will be from IDM
  • central controlled residential ventilation with enthalpy exchanger and heat recovery from Zehnder
Photovoltaics will be included if the budget allows in the end; conduit pipes and meter space will definitely be planned in advance.
Whether this will be the right approach in 20 years remains to be seen. My parents relied on cheap night electricity and electric storage heaters back then – and regretted it.
rick20189 Aug 2019 18:02
I would replace solar thermal with photovoltaic panels. It’s at least more cost-effective and less prone to issues. Otherwise, I agree with Bookstar.
hampshire
9 Aug 2019 22:36
In my opinion, it is no longer appropriate to install a system based on fossil fuels in a new house. Why is the selection so limited?
9 Aug 2019 23:37
It doesn’t have to be that difficult. Both options are available on the market and will keep the house warm. So, even if you choose the wrong one, it won’t be a major mistake. It often comes down to gut feeling. I would also keep climate change in mind, but not in terms of it getting warmer every year. You still need a good heating system in winter.
Rosmarin
10 Aug 2019 12:25
Bookstar schrieb:
Also, decentralized ventilation – trust me, better not.
Hello Bookstar, why is that?
