ᐅ The actuator remains closed and no longer allows the pin to move upward.
Created on: 29 Jan 2017 21:35
crazy5170
We are slowly but surely becoming frustrated. It was supposed to be a simple replacement of a faulty actuator. So we bought a new actuator, swapped it with the old one, and connected the blue and brown wires. However, as soon as we attach the new actuator, it pushes the pin fully down, blocking the flow. Although the two wires are connected correctly, the actuator does not allow the pin to move back up, and the blue part of the actuator is not visible.
We are now wondering what could be causing this.
crazy517030 Jan 2017 06:23Thanks for the idea. However, all the drives are normally closed (NC).
crazy517030 Jan 2017 07:07The room probably cooled down last night. Currently, the left half of the room, which has its own circuit, is warm, but the right side is ice cold.
crazy517030 Jan 2017 07:15The actuator has pushed the pin down, the blue edge at the top of the motor is not visible, and there is no measurable power.
crazy517031 Jan 2017 16:27Because there are quite a few cables inside the junction box and space is limited, I connected the replaced actuator using a terminal block. Could this possibly be the cause of the problem?
