ᐅ End-Terrace House from 1915: Photovoltaic System?
Created on: 1 Apr 2024 19:29
mayor333
We were incredibly lucky to purchase a great end-terrace house (heritage protection only on the exterior) in a fantastic neighborhood.
Built in 1915, but the structure is in excellent condition since it was built before the war.
No moisture in the basement, and the roof is dry.
Heating was provided by gas individual heaters in each room, but these have already been removed.
Living space is about 110 sqm (1,184 sq ft), garden area 450 sqm (4,844 sq ft) in the beautiful Palatinate region.
A gas connection is available.
We now want to renovate and already have an energy consultant who will also oversee the construction supervision.
Initial feedback from the energy consultant:
- Photovoltaic system on the south-facing roof without shading
- Thermal buffer storage recommended
- Ventilation system combined with an earth tube (seems to replace a split air conditioning unit? Does anyone have experience with this?)
- Ceiling heating
What I am considering:
- 10 kWh electric storage battery
- Underfloor heating on the ground floor
- Low-temperature radiators on the upper and attic floors
- Split air conditioning units recessed into the ceiling in the living, bedroom, and guest rooms
We will fully equip the house with KNX automation, including modern and up-to-date control of the heat pump and storage system.
What would you suggest adding, combining, or improving here?
We are in a very comfortable financial situation, in our early 30s, and want to “do it right” this time.
The exterior of the property must be preserved, except for the photovoltaic system on the roof, as environmental protection takes priority over heritage preservation.
Thanks for your suggestions and information.
hanghaus2023
3 Apr 2024 12:54
If 4 kWp can fit facing southwest, then that’s it. Northwest and northeast are, in my opinion, unsuitable due to low yield.
Labradorit
3 Apr 2024 13:23
Cute little house, it will definitely turn out well!
Quick question since it fits the topic: Do you have a rough idea of how much a small photovoltaic system costs? I’m in a similar situation but have no clue which direction to go with a photovoltaic system.
hanghaus2023
3 Apr 2024 13:36
Labradorit schrieb:
Quick question since it fits the topic: Do you have a rough idea of the cost for a small photovoltaic system? I'm in a similar situation but have no clue what direction these systems usually go in.
How large?
With storage? If yes, how large?
I just commissioned a 5.2 kWp system with a 12.6 kWh storage and a 16 A wall charger for 16,000 euros.
nordanney
3 Apr 2024 13:46
As a large balcony power plant, you can buy such a system for well under €2,000 (e.g., 4,050 watts with a single-phase Growatt hybrid inverter for €1,600 plus mounting materials). Then you just need to have an electrician connect it or have it installed on the roof. Does it need to include a battery storage system?
Labradorit
3 Apr 2024 13:48
I don't think we need an attic, but we'll let the experts advise us on that. Thanks for the figures! Now, back to the house that this is actually about, sorry!
hanghaus2023
3 Apr 2024 13:54
nordanney schrieb:
As a large balcony power system
Currently, balcony systems are allowed a maximum of 600-watt heat pump capacity. The change to 800-watt heat pumps, in my opinion, has not yet been approved.
Of course, I can buy the materials much cheaper. Installation on the roof and the certified electrician are not suitable for DIY. My strings reach over 400 volts.
