ᐅ Temporary power distribution box located 100 to 120 meters from the main supply connection point.
Created on: 8 Mar 2015 23:18
derstefanm
I have a question regarding the construction site power distribution box and whether anyone has experience with how it is allowed to be installed. The white power box from the utility company, where the temporary site power distributors are usually connected, is located about 100m (330 feet) away.
My question is, how far away from the supply point can the distributor be installed? The reason I ask is based on the experience at my brother’s construction site two years ago. The distributor was connected right next to the supply point, which meant running 80 to 90 meters (260 to 295 feet) of cable. At 230V, this was still manageable though inconvenient. However, with a 380V cable of 30mm² (about 0.047 in²) cross-section, it becomes much more difficult.
Ideally, the box would be placed directly at the construction site. My only question is whether that can be arranged.
derstefanm9 Mar 2015 12:12I had the same idea and asked the local utility company about it, but they responded that it is not possible. Unfortunately, no explanation was given.
Bauexperte9 Mar 2015 12:14derstefanm schrieb:
I had the same idea and asked the local utilities about it. Their answer was that it is not possible. Unfortunately, they did not provide any explanation.What is that supposed to mean? Are you planning to generate electricity later by using a bicycle?Best regards, Bauexperte
derstefanm9 Mar 2015 12:16No, definitely not, but from the power outlet :P
I don’t understand why it apparently shouldn’t be possible, but I will follow up again because that would be the most cost-effective solution.
derstefanm19 Apr 2015 14:38Does anyone know if it is simply possible to take electricity from a neighbor and install an electrical panel with a meter and circuit breakers in front of it?
Sebastian7919 Apr 2015 20:06I did that earlier at my neighbor’s place – it works, but it is usually not allowed by the utility company. However, you are basically receiving the electricity as a gift from the neighbor.
