ᐅ Tall cabinet with a mismatched end panel
Created on: 7 Mar 2013 20:23
Eriu
Eriu
7 Mar 2013 20:23
we are currently assembling our first Ikea kitchen and are getting a bit frustrated. We were able to resolve most of the uncertainties ourselves, but now it’s about our tall cabinet, which has a depth of 37 cm (15 inches). However, the supplied cover panels are 60 cm (24 inches) deep. Cutting them down wouldn’t be a problem in itself, but we have already noticed with several handle drillings that the veneer of the "Gnosjö" finish comes off very easily. If we were to cut these cover panels now, in my opinion, the cut edge would look sloppy afterwards. Has anyone done this successfully? We have the same issue with the plinth and the cover panels of the wall cabinets... we don’t want a light strip and therefore have to cut those as well.
I’d be grateful for any experiences, tips, and tricks.
Eriu
Nayla_1068
7 Mar 2013 22:55
Hi,
apply masking tape to the areas that need to be cut, mark the lines on the tape, and cut with a proper saw, such as a circular saw with a guide. If you don’t have this kind of tool, many hardware stores now offer cutting services for a small fee.
The veneer must not come loose. Gnosjö is a nice but relatively affordable front. The foil is only glued on, so it is definitely not as durable as paint or veneer. Therefore, apply masking tape again where a handle will be installed. Also, make sure you use the correct drill bit for woodworking. If you notice an increasing number of chips or damages during further assembly, please contact customer service, as it could be a defective batch.
Nayla
Z
zetterberg
8 Mar 2013 08:17
1. The right drill bit
2. a sharp drill bit
and you’re good to go.
Eriu
8 Mar 2013 08:33
So, we're done with the handles for now, but the side panels that need to be cut down are still causing me some concern. The tall cabinet stands alone against the wall, so any chipped areas will be immediately noticeable... I really hope Nayla’s tip works ops:
Z
zetterberg
8 Mar 2013 09:46
The tip will work; a sharp saw blade also helps here.
IKEA-Experte
8 Mar 2013 09:55
You can start by trying to saw off a narrower strip yourself. If it doesn’t work out, you can have it cut professionally. I haven’t had good experiences with DIY stores. They often seem to use saw blades that have been in use for too long. In any case, a coated chipboard panel cut there often has frayed edges.
