Bauherr am L28 Jul 2019 11:42So far, our design includes a 15cm (6 inches) dropped ceiling, which will be installed by the drywall contractor.
The advantages, according to the planner, are mainly the great and lasting flexibility regarding, for example, recessed lighting, as well as the easy installation options for a controlled residential ventilation system.
Of course, we are wondering whether these benefits outweigh the higher costs and if there are any disadvantages. The obvious higher costs include:
- Shell construction (each floor must be built 15cm (6 inches) higher) – we don’t have a good sense of how much extra this might cost.
- Window frame extension by 15cm (6 inches): because we want floor-to-ceiling windows, the frames will need to be raised by about 15cm (6 inches) at the top to be mounted to the concrete ceiling. This adds roughly €5,000 gross to the total window costs. The question is whether installing a lintel by the shell builder might be a cheaper alternative here.
- Costs for the dropped ceiling itself (drywall contractor).
- Increased costs for the larger external surface area (plaster, insulation, painting) – again, we don’t have a clear idea of how significant these extra costs are.
Our planner is very enthusiastic about the dropped ceiling. What are your opinions? Are the advantages really that significant, or are there even additional benefits besides those mentioned? Or have we overlooked other disadvantages or costs?
If you want to install pipes and conduits within the ceiling without lowering it, the ceiling will need to be thicker (for example, due to the slope required for wastewater pipes). Depending on the structural engineering and the position of the pipes, you cannot simply transfer the height one-to-one.
In general, it is more expensive to build taller floors and then install a suspended ceiling. However, this way you won’t need concrete recess housings or similar components.
A suspended ceiling is definitely more flexible and also offers more design options or additional soundproofing measures.
Whether you can or want to afford this is something you will have to decide.
Any additional costs will need to be requested (quoted). Are you building through individual contractors or with a general contractor?
Bauherr am L28 Jul 2019 12:16Thank you for your response. We are managing the individual contracts ourselves (the architect will handle the awarding and supervision).
The 1:1 cost transfer is now clear and makes sense. However, there are items, such as reinforcing the upper window frames, that are additional. 5,000 euros is quite a significant amount, and we wonder if this is one of the reasons why almost no one builds with a dropped ceiling. Apart from the architect, we don’t know of a single-family house with a dropped ceiling.
A suspended ceiling can be worthwhile if you want to install a lot in the ceiling. For example, if you have a strong preference for spotlights, it can be more practical than installing 100 recessed housings. Or if the ventilation system needs to be integrated into the ceiling and this wouldn’t be easily possible otherwise.
As a temporary solution just to get something installed, I find it clearly too expensive.
Bauherr am L28 Jul 2019 12:48We generally prefer not to have too many recessed spotlights and would rather have fewer of those and instead some nice floor lamps.
The ventilation can probably be implemented without a dropped ceiling, as it was in another new build.
However, the electrician will likely be more expensive without a dropped ceiling.
As is often the case in life, we cannot easily quantify the exact cost difference with or without a dropped ceiling at the moment.
