ᐅ Utility lines with excess length
Created on: 2 Jul 2021 19:39
Bärchen2012
Bärchen2012
2 Jul 2021 19:39
Hello forum,
we are currently planning the utility connections. Our plot is a rear lot with an access way of about 30m (100 feet) that we own. We are aware of the higher costs this entails. Upon inquiry, we were informed that the sewer and drinking water pipes end in a pit approximately 1m (3 feet) inside the property. The remaining meters are our responsibility. Has anyone had experience with this? Can this be handled by a licensed electrician (EL), or who should we hire for this?
We would be very grateful for any tips.
Best regards, Jeannette
hampshire
2 Jul 2021 21:44
First, we laid the pipes and cables for the supply up to a handover point at the edge of the property, then the utility providers came and connected them. With some effort, everything was installed so that the street only had to be dug up once.
Bärchen2012
2 Jul 2021 21:52
Did you purchase and install the pipes yourselves, or did you have it done by a contractor?
hampshire
2 Jul 2021 21:59
We contracted the civil engineer for the earthworks and concrete work. Doing it ourselves was too complex and tool-intensive on our property, with more than 10m (33 feet) height difference to the connection point and partially soil class 7.
Bärchen2012
2 Jul 2021 22:05
It's not that bad for us, but we will have the professionals do it anyway. Thanks a lot in advance.
motorradsilke
3 Jul 2021 04:29
We did the sewage work ourselves many years ago. The length was about 35 m (115 feet). The soil here is uncomplicated, mostly sandy soil. It’s a matter of money and physical fitness. Sewage pipes need to be laid quite deep, depending on where the connection to the main sewer line is. In our case, it was about 1.30 m (4 feet 3 inches) deep. You can also rent mini excavators.
