ᐅ Aligning the Substructure (Wood on Wood)
Created on: 21 Dec 2016 23:38
tester23
I need help with the process of aligning the wooden framework.
Please keep in mind that this is my first time doing this, so I would appreciate a detailed explanation.
I have now attached two wooden battens using adjustment screws, but I am not sure how to start aligning the entire structure.
Here’s what I have tried:
1. First, I individually leveled the first five battens (each 4 meters (13 feet) long) lengthwise using a spirit level. Then, to check, I held a straightedge across the five battens, but the fit at the front and back didn’t match. Some battens had a large gap to the straightedge, others only a small one. I thought that if I leveled them lengthwise with the spirit level, they would also all be correct widthwise.
What am I doing wrong, and what is the proper procedure?
Raumdecke mit Holzunterkonstruktion während Renovierung und Fensterfronten sichtbar
Braxman
25 Jan 2017 07:59
Basically, good solutions have already been suggested. What I would additionally recommend is a simple cross-line laser level. For short distances, there are quite affordable devices available on the market.
Set up the line laser in a corner, adjust it to any desired height, and create a reference line at a few points in the room. Now simply measure the distance between the laser and the ceiling using a tape measure. Once you find the lowest point of the ceiling, attach the first batten there and align from that point. If you use the laser for this, you basically don’t need a straightedge or spirit level. When the batten is fixed to the ceiling, take the measurement from the laser to the lower edge of the batten and set this distance at each point where you screw the battens in.
Whether you use spacer screws or shim plates and then fix directly with anchors is a matter of preference. You can then screw the load-bearing battens directly onto the counter battens.
tester23
25 Jan 2017 15:23
Thank you for the replies,
that's exactly how I did it. I bought a 360° laser level from Bosch. It’s simply perfect for this purpose.
Then I mounted it on the wall and adjusted it upwards until it made the first contact (which was logically around the middle), giving me my lowest point.
On the sides, there was about a 3-4 cm (1.2-1.6 inches) difference compared to the middle. I removed the old battens there because they were only 2 cm (0.8 inches) thick and installed new 4x6 cm (1.6x2.4 inches) battens (new base battens). If I now add 3x5 cm (1.2x2.0 inches) battens on top of that, the deviation from the middle is only 0.2-0.5 mm (0.008-0.02 inches), which I can easily adjust using leveling screws. Everything is rock solid on the sides, even better than on the old battens.
