ᐅ Submersible pump trips the residual current device (RCD) when switched on
Created on: 3 Aug 2021 07:44
immermehr
immermehr
3 Aug 2021 07:44
I bought a submersible pump (model 30136). When I switch it on, a residual current device (RCD) always trips. I contacted the manufacturer and received a replacement. The new one has the same issue.
I thought the problem might be with my power supply or wiring. I checked everything again and found no faults.
Then I got another pump (from a different manufacturer) with almost the same power (900W instead of 950W). This one works perfectly.
Could this be a series defect with the pump (manufacturer)?
Does anyone have any advice for me?
THANK YOU all.
hanghaus2000
3 Aug 2021 08:35
You’ve already given yourself that advice. Try other manufacturers.
I just wonder why a submersible pump is protected with a residual current device (RCD).
seat883 Aug 2021 10:39
hanghaus2000 schrieb:
You’ve already given yourself the advice. Try other manufacturers.
I just wonder, why is a submersible pump protected with a residual current device (RCD)?
Well, the outdoor outlet will already be connected through an RCD anyway...
danixf
3 Aug 2021 12:18
immermehr schrieb:
Would anyone have a tip for me?
RCD installed and the pump’s inrush current too high? Try plugging one or two extension reels between the outlet and the pump and test again.
I can’t imagine a manufacturing defect. It has consistently good reviews.
