ᐅ Student Takes on Building a Ventilation System Himself
Created on: 17 Feb 2015 23:04
Z
Zip-Freak
Introduction / Preface
Hello!
My name is Christian, and I am 27 years old. This year, I completed my bachelor’s degree in Energy and Environmental Engineering and am now pursuing a master’s in Renewable Energies. I am an enthusiastic DIYer, if you can still call it that with my own lathe, milling machine, welding equipment, and so on.
Recently, I became the "owner" of a single-family house and am currently renovating it. Being a self-proclaimed "tech geek," I want to equip the house with some nice gadgets. I’m doing the renovation myself, and so far, the work is progressing well. As part of the refurbishment, a central ventilation system with heat recovery is planned to be installed (or at least the ductwork pre-installed).
The planned system
The house has approximately 140m² (1507 ft²) of living space plus a full basement. My plan is to install a central system in the heating basement. This system will be completely self-built as a low-budget solution.
The ductwork
Supply air will be delivered to the bedroom and living room (which is combined with the dining area and open kitchen).
Exhaust air will be extracted from the shower bathroom in the basement and the bathroom with a bathtub upstairs.
Since I am still at the "shell construction" phase, I want to lay all necessary ducts now. Due to structural reasons, I plan to use DN70 HT pipes (drainage pipes) for both supply and exhaust ducts.
QUESTIONS
1. Is there any reason not to use HT pipes (wastewater pipes) for the air ducts?
2. The internal diameter of the pipes is 70mm (2.75 inches). At an air velocity of 2 m/s (6.6 ft/s) in the main duct, I achieve about 28 m³/h (16.5 cfm), which means approximately 14 m³/h (8.2 cfm) each for the living room and the bedroom. Will an air velocity of 2 m/s already cause noticeable airflow noise?
3. The system is intended to provide “supportive” ventilation. Do you think it’s feasible to achieve effective ventilation support with the 70mm diameter ducts?
4. The air must of course flow from the “supply air rooms” to the “exhaust air rooms.” In the living room, I plan to install a ventilation grille in the door for this purpose. However, I want to avoid this in the bedroom for noise reasons and to prevent shortcut airflow. I have heard about sound-insulated wall connectors but don’t really know where to get them. Does anyone have tips?
5. Does anyone with experience in this area feel like visiting my construction site (in 21217 Seevetal near Hamburg) to offer helpful advice? I’m diving into this project completely on my own and would really appreciate the chance to exchange experiences.
Many thanks in advance!!
DerBjoern
2 Mar 2015 10:44
Olli1983 schrieb:
I see it differently... Certainly, plastic pipes require less maintenance... but they either break after 5 years or simply become brittle
You’re hopefully not referring to the DN70 sewer pipes, right?! If you are, then I really hope your statement is nonsense, otherwise many buildings will soon have drainage problems.
Sebastian79
2 Mar 2015 10:47
I think they just wanted to gather posts - they commented on everything everywhere yesterday...
V
Voki1
3 Mar 2015 06:44
Lexmaul79 schrieb:
I think they just wanted to collect posts – they commented everywhere yesterday...
Why would someone want to "collect posts"?
