ᐅ Strange horizontal crease in the wallpaper
Created on: 27 Aug 2024 03:32
Just32k
Just32k
27 Aug 2024 03:32
About 2-3 months ago, we had wallpaper installed in our new build. We did the priming and painting ourselves.
About a week ago, we noticed that in many rooms on the attic and first floor there is a horizontal wrinkle several meters long in the wallpaper. The wallpapering was done with glass fleece. In my opinion, the wrinkle appeared several weeks after the wallpaper was applied.
Could the wrinkle be related to higher temperatures inside the house? We are not living there yet, and some of the roller shutters were not electrically connected, so in the last two weeks, there was strong sunlight and high temperatures.
Could the plaster have contracted due to the temperatures? Or could the new build have settled slightly because of the temperatures, causing the wrinkle?
What’s strange is that the wrinkle is about at the same height in all affected rooms. The exterior walls were built with calcium silicate bricks.
At first, we feared that horizontal cracks might have appeared throughout the house, but I opened the wrinkle at one small spot and did not find any crack.
Does anyone have an idea what might cause this wrinkle? Could it indicate a serious problem?
Thanks and best regards.
Diagonal er Riss in einer weißen Wand, Hinweis auf Baumängel.
Just32k
27 Aug 2024 03:54
A few additional notes:
1. The wrinkle only appears on the wallpaper on the exterior walls. It does not occur on the interior walls (drywall), where there is naturally no plaster.
2. So far, we have not noticed any wrinkles on the ground floor. However, they are present in many rooms on the attic and first floor, always at the same height.
3. The shell construction was completed over a year ago, so it has already gone through one summer and one winter.
nordanney
27 Aug 2024 08:19
Just32k schrieb:
About a week ago, we noticed a horizontal fold running several meters in the wallpaper in many rooms in the attic and first floor.
These are likely cracks in the plaster that have become too large for the wallpaper to hide.
Report the defect and have your construction company inspect it.
Just32k schrieb:
Does anyone have an idea what the fold could be? Could it indicate a serious problem?
Cracks in the plaster or, in the worst case, in the masonry. Serious problem? The crystal ball says: maybe yes, maybe no. If you check or have it checked, we’ll know more.
Just32k
27 Aug 2024 08:36
Thank you for the feedback.
The developer is now insolvent, so there is nothing that can be done from their side.
By checking, do you mean simply cutting the wallpaper along the fold or removing the entire strip? Or the whole wall?
We tried it on a smaller area along the fold, and no crack was visible there. So should we open up a larger area?
nordanney
27 Aug 2024 09:22
Just32k schrieb:
Does checking mean simply cutting the wallpaper at the fold or removing the entire strip?
Check where the fold is. Take photos and share them here. I would remove the entire strip. Then, ideally, you can just apply a new strip afterward.
Schorsch_baut
27 Aug 2024 10:48
nordanney schrieb:
Those will be cracks in the plaster, large enough that the wallpaper can no longer hide them.
Or compression caused by settling or shrinkage of a joint. The only solution is to check it out.
