ᐅ Staircase offset by 10 cm – what are the options?
Created on: 4 Jan 2022 00:43
morgenstern
morgenstern
4 Jan 2022 00:43
I am building a single-family house with a general contractor.
After the screed was laid, it was noticed that the staircase is offset by 10cm (4 inches). That means it starts 10cm too early.
According to the plan, there should be 1.05m (41 inches) of space in front of the stairs, but currently, there are only 94cm (37 inches).
As a result, the last step at the top is 10cm (4 inches) lower than planned (according to the plan, the last step was not supposed to be a full step).
The staircase is a straight two-stringer staircase. Since the house has a basement, the staircase cannot simply be shortened because it would otherwise be unsupported.
Are there any options to reduce the stairwell opening? The floor (or basement ceiling) is made of 18cm (7 inches) concrete (prefabricated concrete slab).
Even during planning, the 1.05m (41 inches) space in front of the stairs felt a bit tight; I would be glad to have at least 1 meter (39 inches) here.
Thank you,
morgenstern
11ant4 Jan 2022 13:41
I assume we are talking about
morgenstern schrieb:
Here are the drafts from provider F:
? – still, I don’t fully follow your words. At first, it sounds like
According to the plan, there should be 1.05 m (3 ft 5 in) of space in front of the stairs; currently, it is 94 cm (37 in).
as if the stairs start closer to the exterior wall, but then
Therefore, the last step at the top is 10 cm (4 in) lower (according to the plan, the last step would not have been a full step).
it rather seems that the heights don’t match (?)
morgenstern
4 Jan 2022 15:22
but rather as if the heights were incorrect (?)
The heights are correct. By "10cm deeper," I meant a 10cm (4 inches) larger tread width. So "deep" in terms of depth, not height.
11ant4 Jan 2022 15:40
The heights are correct. By "10cm deeper" I meant 10cm wider step depth. So "deeper" not in terms of height.
Wait, so the top step is not just a landing, but has the full tread length, and the bottom one fits shoe size 58?
driver55
4 Jan 2022 16:08
So, wait – the top step isn’t just a landing, it has a full tread length, and the bottom one is sized for shoe size 58?
Pictures would be helpful.
But there’s probably very little you can change there. (Unless you tear it out and do it once again, properly).
morgenstern
4 Jan 2022 16:25
I will upload pictures this evening, as I am currently only using my phone.
I’ll try to give a brief summary again—sorry if I explained it too complicatedly.
The plan was for a staircase where the top step would be only half the usual tread depth (about 15cm (6 inches) instead of 29cm (11.5 inches)). However, it was built with almost the full tread depth, so the staircase extends 10cm (4 inches) too far into the hallway at the bottom.
The staircase builder adapted to the existing conditions because the stair opening had already been planned 10cm (4 inches) too large. The staircase design never matched the planned stair opening.
To fix this, the stair opening would have to be reduced by 10cm (4 inches), the metal substructure removed, shortened, and then reinstalled.
