ᐅ Stabilizing IKEA BESTA units – what helps prevent slight wobbling?
Created on: 20 Jul 2020 09:12
Charlieme
I have an IKEA Besta media wall unit that I generally like a lot, but unfortunately, there is a small issue: it wobbles slightly, especially when bumped or when opening the doors. I’ve already checked that all the screws are properly tightened, and the unit is placed on a level floor, yet the slight wobbling remains.
My question is: What measures or tricks would you recommend to effectively stabilize an IKEA Besta media wall unit that wobbles a bit? I am interested in both commercially available solutions like stabilization accessories and practical DIY methods that might not be widely known.
What has worked best for you, especially with more recent models where the back panels may be a bit thinner?
I look forward to your experiences, tips, and concrete suggestions.
Rhett
20 Jul 2020 13:09
Reinforcing the back panel often helps the most. The thin particleboard barely withstands lateral forces. It is best to glue or screw in a stronger panel and connect the modules together.
rekijan
20 Jul 2020 13:54
Exactly! And if you want, you can even do a bit of “upcycling” by installing a nice wooden board. It looks good and makes the cabinet really sturdy. Plus: When moving, you definitely don’t want everything to be wobbly.
FLONE41
21 Jul 2020 08:17
I understand the frustration when furniture wobbles and feels unstable. Stability is especially important if you have children or pets.
Have you considered securing it to the floor? Sometimes the wall unit can slip unnoticed, even if it appears to be properly adjusted. I also placed small rubber mats underneath mine, which greatly reduce slipping.
Charlieme
21 Jul 2020 09:33
Cecilera66 schrieb:
IKEA provides special metal brackets for this. Just screw them to the wall at the top and attach them to the furniture.
Thanks for the tip, I actually haven’t installed the metal brackets yet.
Danial schrieb:
Have you checked if the floor might have slight unevenness?
I checked the floor with a spirit level; it’s almost perfectly flat. However, I acknowledge there might be small height differences under the feet.
Do you have experience with IKEA’s adjustable feet? Does adjusting them usually eliminate wobbling, or is it more of a last resort?
Are there any specific recommendations for the back panel material to significantly improve stability?
KODAN32
21 Jul 2020 10:47
Charlieme schrieb:
Are there any specific recommendations for the type of panels to use for the back wall to significantly improve stability?
Certainly: plywood panels with a thickness of 6 to 10 mm (1/4 to 3/8 inch) are very suitable. They are stable, resistant to warping, and easy to cut. It is important to fasten them extensively using wood glue and screws, ideally attaching them directly to the cabinet carcasses as well. You can either remove the existing thin back panel or add the plywood on top. Alternatively, HDF panels of similar thickness can be used, but they are less durable than plywood.
Adjustable feet are not just a last resort; they are particularly helpful for minor floor unevenness and should always be properly adjusted.
