ᐅ Stability of OSB Panels
Created on: 24 Jul 2012 19:17
HugoP-1
24 Jul 2012 19:17
I want to convert my roof space primarily into a storage area. The attic floor consists of wooden joists spaced one meter (3.3 feet) apart. I plan to screw OSB panels onto them. The sales assistant at the hardware store recommended a panel thickness of 22 mm (7/8 inch).
He saw no issue with some of the panel joints lying directly between the joists. That seems a bit weak to me, but I also don’t want to always align the joints exactly on a joist for better stability. What do you think? Are the panels strong enough? I also want to store some heavy furniture in the attic.
MODERATOR
25 Jul 2012 13:51
Butt joints between the joists are not advisable, as this will cause instability; furthermore, a spacing of 1.0 meter (3.3 feet) is too wide for most floor panels, definitely for a 22mm (7/8 inch) thick panel.
I consulted a load capacity chart for OSB panels: with a support spacing of 1.0 meter (3.3 feet) and a panel thickness of 25mm (1 inch), the maximum allowable live load is 1.0 kN/m² (20.9 psf). This is barely sufficient to consider an attic floor walkable.
For storage purposes, this is not adequate. Based on balcony live load standards, I would expect a requirement of around 4.0 kN/m² (83.5 psf), which your floor structure would need to meet.
It is best to contact an OSB panel manufacturer and describe your project; they will certainly advise you on the best option regarding panel type, thickness, and support spacing.
HugoP-1
26 Jul 2012 06:09
Thank you, Hertweck, your response is helpful. I will contact the manufacturer directly.
Ricardo-1
17 Feb 2015 10:09
Hi,
I have a similar idea and am therefore looking for possible solutions. That’s why I inquired about these OSB boards. They are a good and cost-effective option. These OSB boards are well suited for interior construction. Here, I am using the OSB2 board.
herrmann-1
10 Aug 2015 13:09
I also used these OSB panels for the attic. I chose a thickness of 22 mm (7/8 inches). I placed some furniture on the floor, and I believe this thickness is the right choice.
Robert-1
28 Dec 2015 11:39
Alright, the rafter width is one meter (3.3 feet), so the spacing is not very large. I also installed OSB panels with a thickness of 30 mm (1.2 inches). That is sufficient, and loads can also be supported here.
