ᐅ Split air conditioning system and mechanical ventilation with heat recovery
Created on: 16 Mar 2023 11:30
Rafaelsen
Does anyone have experience with a split air conditioning system combined with a central controlled residential ventilation system with heat recovery?
The main question is whether the controlled residential ventilation can distribute the cool air from the air conditioner and how well or poorly this works.
My idea: Because of the simplicity and short distances, I am considering a split air conditioning system with 2 indoor units.
The outdoor unit would be placed on the garage, and from there it is only about 50 cm (20 inches) through the wall into the bedroom upstairs and the living room downstairs. Power supply is also available. I want to avoid major effort and long duct runs to actively cool all rooms. The children’s rooms are not as easy to reach. It would be possible via an external duct on the outside wall, but I want to avoid that for aesthetic reasons.
The house was built in 2018 and exceeds the KfW 55 efficiency standard.
The primary energy demand is calculated at 42 kWh/m² (square meter) and the values from recent years confirm this.
We have 178 m² (1,914 square feet) of living space according to the living space ordinance and about 212 m² (2,282 square feet) of floor area. No basement and a gable roof are present, which explains the discrepancy.
Heating is provided by a ground-source heat pump with a water circuit, which is also equipped with a cooling function.
Cooling via the underfloor heating works satisfactorily and keeps the temperature around 24°C (75°F) even in midsummer.
However, it requires consistent shading and following recommendations. Once the heat has entered, it takes several days for the cooling system to lower the temperature again.
In 2022, we consumed 2,169 kWh of electricity and generated 9,408 kWh of heat for heating and domestic hot water.
The building is therefore comparatively efficient in terms of insulation.
We still want to get advice regarding the air conditioning. Both rooms are about 40 m² (430 square feet), and the question arises whether it makes sense to choose a more powerful air conditioner to have more cold air for distribution?
The controlled residential ventilation also supports this to some extent. In summer, it cools the outside air by a good 8°C (14°F).
The air volume flow is approximately 180 m³ (6,360 cubic feet) per hour on automatic setting.
Would the controlled residential ventilation noticeably distribute the cool air from the air conditioner and cool the other rooms, or would we rather get cooling zones within the house?
steuerlexi
5 Sep 2024 10:38
rick2018 schrieb:
This would be an example of a setup with a refrigeration unit and chilled water system.
However, there is still a dew point issue with the piping.
To continuously cool a flow rate of 300 m3 per hour (about 176 cubic feet per minute), you need quite a bit of power.
When the outside temperature reaches 30°C (86°F) or higher, you first have to cool it down.
I recommend using multiple indoor units, either as a multi-split or single-split system. This provides significantly more effective capacity, better efficiency, and more precise control.
On very hot days, you should switch off the controlled ventilation system.
Yes, I suspect you are right. I wanted to avoid multiple units if possible, but I realize now that won’t likely work. Yesterday I bought this "Midea Portasplit" from the hardware store and I’m currently testing how much cooling I can achieve with it. It was already quite cool downstairs yesterday.
rick20185 Sep 2024 10:39
Ok, that’s basically what I mean. You can’t cool down too much with it, as condensation would form on the pipes. But it should definitely help somewhat. I’m installing 2–3 more air conditioning units in the house. That way, you’ll have all options and can also cool effectively in extreme temperatures.
rick20185 Sep 2024 10:45
Exactly 2-3 units of 3.5 kW and you can control it however you want. Depending on the location in the house, a multi-split system can also make sense—one outdoor unit for several indoor units.
With portable units, the installation effort is lower. However, they are more expensive, usually less efficient, and noisier.
3.5 kW units start at around €600 (including app control).
