ᐅ Sound Issue: Is Noise Transmitting Through the Masonry or the Exterior Render?
Created on: 31 Jan 2017 15:15
Nafetsm
We built in a small suburb of Ulm, close to a secondary road with about 6,000 vehicles per day. The road is roughly 20–30 meters (20–30 yards) away, and there are still vacant lots on both sides of our property.
The construction uses Poroton bricks for the masonry.
During the sale, we were assured that noise would only be an issue through the windows, which is why we installed special roller shutter boxes and partly soundproof windows.
Currently, there is still scaffolding around the house, which is connected to the house and the ground. The exterior plaster has not yet been applied and will follow later. What unsettles us is that we can constantly hear the road noise, and depending on the wind and weather conditions, it becomes even more noticeable. This occurs on every floor and practically in all rooms, even those with soundproof windows (class 3). It feels as if a window is permanently tilted open. When we put our ear against the wall, we can clearly hear the noise coming through the wall. The sound is much quieter near the windows. It is clear that the noise is coming through the masonry. In areas where concrete columns have been inserted, no noise passes through. Around the house, there is naturally no vegetation yet, as it is newly built.
What has been your experience? Is this a common weak point of these bricks? Could the scaffolding, which is connected to the ground and the house wall, be transmitting the noise so clearly? And can we hope that when the exterior plaster is completed, the masonry joints will be sealed well enough to significantly reduce the road noise?
I am very interested in your experiences and opinions.
Patrick
Nafetsm2 Feb 2017 22:31
Really, why? How is the situation with you, Alex?
alex87
27 Feb 2017 20:37
So.. the base plaster is now applied, but unfortunately there has been no improvement. The noise is still clearly audible through the masonry.. now a roughly 5mm (0.2 inches) layer of plaster will be added, hopefully that will help!
The roller shutter boxes are still "empty" as well, a lot of sound can pass through there too, right?
lastdrop27 Feb 2017 21:05
Sure, it’s like a hole.
Nafetsm28 Feb 2017 12:10
Yes, that clearly explains why there has been no improvement yet. The roller shutter box is already a weak point... and it will be open anyway.
readytorumble
28 Feb 2017 12:35
Is the roof already insulated? So far, we only have the interior plaster (also Poroton 36.5), and the noise comes through the uninsulated roof. That’s understandable since there is only an underlay membrane and tiles on top...
nightdancer
28 Feb 2017 12:39
Patrick
Lack of planning, poor construction workmanship, and unsuitable choice of building materials.
At this point, I would have only worked with calcium silicate masonry and only installed exterior roller shutters on the masonry. The method of window installation should also have been planned. Additionally, noise could also come through the roof. Money was saved in the wrong places.
