ᐅ Sound insulation for geothermal heat pump in the utility room
Created on: 26 Sep 2020 12:27
fab101
I would like to reduce the humming noise from our ground source heat pump in the utility room. This humming can be heard outside the utility room.
1) Should I better insulate the heat pump itself or the walls of the utility room?
2) Depending on the approach, which materials are suitable for sound insulation? I was thinking of Basotect foam?
Good luck, F
Good luck, F
Soundproofing or noise reduction involves several factors. You could install a soundproof door, but this will only be effective if the walls do not allow much sound to pass through.
You should also consider potential issues with temperature and ventilation if you seal the room. Do you have a mechanical ventilation system with heat recovery? Sound can also be transmitted through this...
Whether you can enclose the heat pump is something I would clarify with the manufacturer, as there could be problems with heat buildup, etc.
