We are making great progress in planning our new house, thanks to our architect.
The next important decision, in my opinion, is the wall construction.
How should it be structured?
…if a good indoor climate (both summer and winter) and effective thermal insulation are a high priority.
I believe costs should be secondary at this stage.
What should the wall assembly look like?
The only fixed element is the facing brick.
Barossi
Barossi
nordanney16 Nov 2015 20:08Since you have already decided to use cladding, your architect can probably design a suitable wall structure using sand-lime brick with cavity insulation, depending on the desired energy efficiency level.
In my experience, the indoor climate is quite similar across all types of wall constructions – without proper ventilation, they all feel airtight and stuffy, and in summer, without air conditioning, heat will enter any house.
Only eco-friendly construction with clay plaster stands out to me, as the wall can actually breathe a little or absorb odors.
Sebastian7916 Nov 2015 20:13With lime-cement plaster, the wall structure is also vapor-permeable and can "breathe." Adding silicate paint on top creates a wall assembly that effectively regulates moisture.
Then you would have to ventilate very often, although I don’t think fixed intervals are entirely accurate. An open-plan living-dining-kitchen area of 70 m² (750 sq ft) occupied by two people doesn’t necessarily need to be completely ventilated every two hours. It’s best to have 3 m (10 ft) ceiling height, which allows for even more fresh air reserve.
