ᐅ Solar Heating Support
Created on: 25 Oct 2015 15:31
Kerstin2
Hello, we are currently planning our new build. We are choosing a gas heating system with solar support for domestic hot water. Would you also consider solar support for space heating?
Would you also connect a hydronic fireplace?
ölschlamm
22 Nov 2015 11:46
@ Bauexperte
Bauexperte schrieb:
Knowledge about house construction is about the same as that of most building laypeople here.
That is not decisive, because the construction specifications I have were created by the licensor, and I should be able to assume that the parent company has sufficient expertise...
Bauexperte schrieb:
the "if/then" conditions will probably be found in the fine print
That makes more sense to me – but how would that look specifically? Would the fine print say that the house has to be fitted with a different heating system if the building permit / planning permission is denied due to an energy calculation error? It’s hard to imagine, isn’t it? Especially if this is prepared nationwide and hundreds of homeowners end up stuck because of it?
@Thorsten
I can only repeat:
There will be a solar domestic hot water system with two panels installed.
The external wall is 24cm (9.5 inches) aerated concrete without additional insulation.
The roof apparently will be insulated quite extensively.
Controlled ventilation is mandatory, but only a very simple, decentralized system (Lunos ego).
I don’t think we can resolve this disagreement – strictly speaking, it doesn’t really belong to the main topic of this thread anymore. If I decide to pursue this, I will have the building contract carefully reviewed and specifically point out this issue. As I said, I also believe that it is not acceptable.
T21150
22 Nov 2015 11:55
@Ölschlamm: From my point of view and perception, we don’t have any points of disagreement.
I’m keeping my fingers crossed for you.
Best regards, Thorsten
ölschlamm
22 Nov 2015 18:42
Oh, I expressed myself a bit awkwardly there. I meant rather controversial, in the sense that it actually shouldn’t be the case – as we both assume – but the general contractor claims otherwise.
