ᐅ Socket Placement
Created on: 22 Dec 2019 18:54
Andre77
Hey,
which location would you prefer for the electrical outlet?
In the corner on the exterior wall or next to it on the interior wall?
Andre77
12 Jan 2020 15:43
Well, clearly this is not suitable for a junction box.
I am currently considering whether to outsource the additional boxes externally instead of having the general contractor’s electrician do the work.
Plus a few other network/electrical tasks.
"My" electrician also has no objection if I supply the materials myself, which ends up being somewhat cheaper when I compare prices.
Mycraft12 Jan 2020 15:54
What is the wall construction? This makes a big difference. Poroton, drywall (plasterboard), timber frame, or sand-lime brick—there are significant differences between these.
Andre77
12 Jan 2020 16:01
Poroton bricks and some drywall
Mycraft12 Jan 2020 16:31
Hmm, then it’s quite simple and quick. Both create quite a lot of dust (so a vacuum cleaner is necessary). It shouldn't take longer than 5 minutes for a professional.
Andre77
12 Jan 2020 16:40
Ah, wow... that was fast after all.
bauenmk202012 Jan 2020 16:40
Andre77 schrieb:
Well, obviously this is not just for one outlet.
I’m currently considering whether to subcontract additional outlets externally instead of having the general contractor’s electrician do it. Plus some other network/electrical tasks.
"My" electrician also has no problem if I provide the materials myself. That ends up being a bit cheaper when I compare prices.
Does the general contractor allow this so easily? Is the electrician directly employed by the general contractor or was the electrician hired through a tender or subcontract by the general contractor? Couldn’t the general contractor’s electrician arrange the work with you separately, meaning you simply get a quote directly from the electrician without going through the general contractor?
Have you asked who will be responsible for the warranty on the electrical installation?
